Starting problems again
Old Nov 26, 2004 | 03:33 PM
Acura EL's Avatar
Default Starting problems again
guys, have anybody had problems connecting non-Honda batteries on CRX? I have put a new battery in and it looks like the positive connector doesn't fit the clamp properly. The car barely starts and loses charge at the traffic stops (light dimming and radio off) ...
Pls, help ...
Old Nov 26, 2004 | 04:48 PM
Acura EL's Avatar
Default Re: Starting problems again (Rebel CRX)
BUMP
Old Nov 26, 2004 | 04:51 PM
dr_latino999's Avatar
Have you checked to see if your alternator is operating properly?
Old Nov 26, 2004 | 04:53 PM
Lil Red CRXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rebel CRX &raquo;</TD></TR><TR><TD CLASS="quote">guys, have anybody had problems connecting non-Honda batteries on CRX? I have put a new battery in and it looks like the positive connector doesn't fit the clamp properly. The car barely starts and loses charge at the traffic stops (light dimming and radio off) ...
Pls, help ... </TD></TR></TABLE>
To me sounds like your Alternator is bad,cars don't care what type battery you put in them.Next time you start it-take the pos. cable off the battery,bet it dies out-bad alt.
Old Nov 26, 2004 | 04:58 PM
mr. carpenter's Avatar
Default Re: Starting problems again (Lil Red CRXsi)
maybe try new post clamps.
Old Nov 26, 2004 | 05:03 PM
EFin' Kyle's Avatar
Default Re: Starting problems again (mr. carpenter)
ALTERNATOR!!! u have a bad bearing i believe. same thing happend to me. i got a new alternator and it worked fine. good luck. u should be able to ehar the bearing if it is bad or not when the car is running and u open teh hood.
-Kyle
Old Nov 26, 2004 | 05:38 PM
Acura EL's Avatar
Default Re: Starting problems again (crxstreetracer90)
this is strange to hear but I hope you are right. Previously, I was told that if it was an alternator problem, I'd not be able to start the car at all not talking of driving it.
I am usually able to start and drive it but then the electrical charge seems to drop or something. ...
BTW I don't hear any noise from alternator (my CRX is usually very quiet). I know that my alternator has not been replaced in a while ...
Old Nov 26, 2004 | 07:08 PM
HatchBox's Avatar
Skoobie no more...
happend to my old maxima, loose connecton on the + terminal.
would die when stopped at light or stop sign.
changed terminal connecters and it was fine.
bindolus
Nov 4, 2015 07:05 PM
i_VTEC
24
Jan 19, 2015 03:32 PM
LoveOfMoney
Aug 24, 2007 12:26 PM
Freezen
Aug 6, 2007 01:12 PM
_bB
Jun 11, 2004 06:53 PM
