cx to ex brake swap
Old Nov 26, 2004 | 10:06 AM
skunk2eg's Avatar
Default cx to ex brake swap
on a 93 cx i'm going to put on ex rotors and calipers pads etc., is it required to replace the brake lines and master cylander too?
Old Nov 26, 2004 | 10:17 AM
Targa250R's Avatar
be professional
Default Re: cx to ex brake swap (skunk2eg)
No and no. Neither is required.
However, you may want to swap in a slightly larger master cylinder anyway to improve pedal feel. Don't use the '92-95 EX master cylinder though, since AFAIK it is the same 13/16" unit as in your CX (unless you get one from an EX w/ABS, which will be 15/16", but will require reflaring one of the lines).
Ideally, you'll want to get a '90-91 Civic EX sedan master cylinder. It is 15/16" and is a direct bolt-on swap. No line modifications are necessary.
JMO.
Old Nov 26, 2004 | 10:22 AM
pdiggitydogg's Avatar
wanna buy my ex brake set?
punkracer
Suspension & Brakes
Mar 15, 2010 01:32 PM
ej14life
Nov 26, 2009 04:33 PM
ludesrv
Oct 25, 2008 02:37 PM
dem0nk1d
Mar 21, 2008 07:07 PM
