HELP, coolant leak!!!!!!!!!!!!
Old Nov 26, 2004 | 09:21 AM
rafiq7's Avatar
Default HELP, coolant leak!!!!!!!!!!!!
the leak is coming from the right side of the engine, away from the hose'.
I dont see any hose,
Old Nov 26, 2004 | 10:14 AM
sabotage7's Avatar
Default Re: HELP, coolant leak!!!!!!!!!!!! (rafiq7)
do you mean the right side...as in if you're looking at the engine? take some pics!
Old Nov 26, 2004 | 01:19 PM
dick_213's Avatar
Default Re: HELP, coolant leak!!!!!!!!!!!! (sabotage7)
probably means the right side as in the non principal end or the timing belt side. in that case im gonna guess your water pump is going out.
Old Nov 26, 2004 | 02:08 PM
rafiq7's Avatar
Default Re: HELP, coolant leak!!!!!!!!!!!! (dick_213)
yes, the timing belt side.
Old Nov 29, 2004 | 03:29 PM
crxb20ed's Avatar
water pump.... or o-ring on coolant pipe
Old Nov 29, 2004 | 04:38 PM
sfr4dr's Avatar
Default Re: HELP, coolant leak!!!!!!!!!!!! (crxb20ed)
I had a drip from the same area and it was the water pump o-ring. The whole pump gets replaced though.
Old Nov 30, 2004 | 09:16 AM
rafiq7's Avatar
Default Re: HELP, coolant leak!!!!!!!!!!!! (sfr4dr)
thanks,
i went ahead and got my water pump replaced, along with my timing belt, drive belts, oil pump, and valve cover gasket.
95DC2GS-R
Aug 12, 2009 05:23 AM
wedtm
Mar 26, 2008 07:59 PM
Lude-Lee
Feb 18, 2008 07:50 PM
Seye
Mar 28, 2004 03:26 PM
Sephro
Mar 20, 2003 11:19 AM
