Fullybuilt LS/vtec what are some numbers to expect?
the block is a b18a and i got it buit weeks ago basically it 12to1 compression has Golden Eagle Iron Sleeves, Wiseco pistons 85mm, Eagle connecting rods, Bore & Hone, Hot tank, Deck, Balance and Micro Polish LS Crank shaft
the head is off a 98 gsr modifications are.Degrease/clean cylinder heads, Port and polish, Deshroud valve and chamber area, Polish chamber, 3 angle valve job running skunk2 stage 2 with crower spring Im also have a set of twm individual throttle bodies with 440cc injectors that are going on as for the tunning runing hondatas100.
any set ups the same list them please any info r whatever is cool!
just tring to c what else should i do
jaydmcrx
13
Jan 4, 2004 04:24 PM
