Honda S2000 Honda S2000
Newbie to S2K
Old Nov 26, 2004 | 08:37 AM
03Si's Avatar
Default Newbie to S2K
hi all, i've just traded my old car the day before thanksgiving for a 2001 S2K. the car was beautiful and has an exterior like right off of show room floor, and the interior is perfect. best of all, the car only has 15000 miles on the odometer, and is completely stock, and i couldn't have been happier with this car. some old guy had it before me, and it was a leased vehicle (got the info from carfax). and i'm guessing it was a garage queen.
well, since i'm a newbie here in the S2K world, i like to know what grade of gasoline do you all use in your S2K's? regular, mid-grade, or premium? i live in florida, and we have 93 octanes here.
also, i'd like to know what's the wheel sizes on the 2001 S2K's. it seems like the wheels are staggered, just wasn't sure what width.
and if there are any flaws i should be aware of my car, pros and cons and all.
btw, the automatic one touch power window button on the driver side don't seem to work well. i know it works, but it doesn't lower the window all the way sometimes. curious.
Old Nov 26, 2004 | 10:20 AM
WowOzYouRock's Avatar
Default Re: Newbie to S2K (03Si)
use premium gas all the time ... the only flaw that i know off is that the differential seem weak so be aware of that ...
BTW, welcome
Old Nov 26, 2004 | 10:24 AM
papa5murf's Avatar
well first off ... welcome to the family.. you made a very good choice..
and the gas i use 93octane...... always use premium grade gas, nothing less.....
and the wheels are staggered... 16x6.5 in front.. 16x7.5 in rear...
and as for the pros and cons.....check your first and second gear... there's a problem with the syncros grinding..... they might of already fixed it tho.... and ummmm... since it's a used car they probably got all the spring spacers out... and i think thats pretty much it..
enjoy the car..
Old Nov 26, 2004 | 10:25 AM
papa5murf's Avatar
Default Re: Newbie to S2K (03s2kblue)
oh yeah. .as y2k_s2k says.. the rear diff is weak......don't do to many clutch drops...
Old Nov 26, 2004 | 11:12 AM
fknfast's Avatar
the window regulators go bad i think theres a tsb on the older s2ks. theres also a rattle on deceleration sounds like the motor but its the springs on the clutch disk they become loose and rattle i think theres a tsb on that too.
just a few pointers
congrats on the new car!!!!
Old Nov 26, 2004 | 01:42 PM
evil vapor's Avatar
Default Re: Newbie to S2K (fknfast)
welcome! as said, use premium grade fuel, and if you don't notice anything broken, there's no need "looking" for something to go wrong. You'll know if something is wrong.
The window problem should be fixed by your dealer, there is a service bulletin on it.
Old Nov 27, 2004 | 09:39 AM
03Si's Avatar
Default Re: Newbie to S2K (vapor)
do you think the dealer will still fix the problem eventhough the car is out of warranty?
Old Nov 27, 2004 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03Si &raquo;</TD></TR><TR><TD CLASS="quote">do you think the dealer will still fix the problem eventhough the car is out of warranty?</TD></TR></TABLE>
of course they would fix it but you have to pay ... i have the same problem ... they said, " poor internal power window motor ground" ...so they ended up replacing the motor/regulator assembly free of charge (under warranty)...
Old Nov 27, 2004 | 06:24 PM
evil vapor's Avatar
what do you have to lose trying?
sneakychaos
Jan 16, 2015 06:02 PM
db_de_luxe
Feb 12, 2012 09:52 PM
BAMbam160
Honda S2000
Dec 6, 2006 12:32 PM
Jon D
Dec 4, 2003 05:21 PM
