13:1 H23
Old Nov 26, 2004 | 08:36 AM
BokChoy's Avatar
Default 13:1 H23
I have an H23 88mm bore with a full gude head package. I ordered weisco ultra lights 11:1 and they sent me 11:1 for an H22. So my compression is like 13:1 now, is this workable on pump gas? 93 octane. This motor has every possible bolt on and only a unichip to tune with. It also has clevite bearings and crower rods, so the bottom end is strong. If it works what kind of numbers should I expect?
Old Nov 26, 2004 | 09:33 AM
PirateMcFred's Avatar
Default Re: 13:1 H23 (BokChoy)
What is your specific setup? What are the cam specs? What do you have for a header and exhaust?
Pirate
*edited to remove misinformation*
Modified by PirateMcFred at 8:18 PM 11/26/2004
Old Nov 26, 2004 | 10:23 AM
hybrid_vtec's Avatar
Default Re: 13:1 H23 (PirateMcFred)
Curious to see the results of this!
Old Nov 26, 2004 | 11:28 AM
Default Re: 13:1 H23 (hybrid_vtec)
Me too *giggle*
I bet you can get over 175wtq depending on what the cams are and how good the tune is.
Pirate
Old Nov 26, 2004 | 02:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Me too *giggle*
Pirate</TD></TR></TABLE>
DAMN! Thats enough to make me want to build one of these too! I love nonvtecs!
Old Nov 26, 2004 | 02:16 PM
hOndafienD 04's Avatar
damn! i wanna see the results of this...but i believe 13:1 is too high for the street even with good tuning....but lets wait and see..what are your other mods? specifics please. and cam choice
Old Nov 26, 2004 | 02:41 PM
I don't think I am being too outrageous stating that. I have a similar setup all stock and I made 169wtq. So cams and headwork should make more right?
Pirate
Old Nov 26, 2004 | 03:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">I don't think I am being too outrageous stating that. I have a similar setup all stock and I made 169wtq. So cams and headwork should make more right?
Yea I read that thread! Very creative, something to make ppl say, WTF!!!, when you beat someone with it and they find out what it is!
Old Nov 26, 2004 | 05:23 PM
BokChoy's Avatar
My specific set up includes:
Crane ignition, Nology coil, aem pulley's, fuel rail, cai,B&M fpr,big plug wires DC sports 4-1 header 2.5" mandrel bent, test pipe with thermal dynamics cat back
Quaffe lsd, fidanza 12lb, act stage 2
bullfrog stage 2's .420 lift/421lift, 258 duration ( I can't remember)
bullfrog t.b. (74mm), C.N.C.'d I.M., PNP .05 over with 5 angle valve job
Titanium valve train and retainers with dual spring
Darton sleeves (88mm), weisco ultralights (12.6:1, head milled 2 thousandths so..)
Crower rods, Clevite bearings, balanced crank, cometic head gasket, arp studs, a zex kit but doesn't look good for that thing (for sale) Maybe more I can't remember? Will I run out of injector, they are stock, so is my fuel pump. Not assembled, just been putting the pieces together, should I flat cut my pistons to drop the cr? head package came with a gude spec ecu and I also have a uni chip, but I think I should upgrade.
Modified by BokChoy at 7:48 PM 11/26/2004
Old Nov 26, 2004 | 05:54 PM
damn you should have that beast dynoed!
Old Nov 26, 2004 | 06:00 PM
Btech0's Avatar
Default Re: (hOndafienD 04)
sounds like a bad *** car
Old Nov 26, 2004 | 06:16 PM
OK I am sorry I fuxored up the calculation. THe difference in compresison height is .030" between the H23 and H22 pistons. I would reccomend sending them back to Wiseco and get some H23's. But with the following I calculate you will be at 13.1:1CR:
88mm bore
95mm stroke
50cc head
3.25cc dome
.024" Head gasket
piston to deck clearance of -0.018" (out of the hole)
You need to correct that or you might have Piston to head contact at High RPM. You can fly cut the pistons but 0.030" is a lot IMO. Really If you spent $500 on pistons you should get what you paid for. Sorry if I pissed on your campfire.
Pirate
Old Nov 26, 2004 | 06:50 PM
BokChoy's Avatar
13:1 is too high, what is the highest you would go? Has anyone ever had their pistons flat cut? or is that just a cheap way to wreck an expensive piston? And is my stock fuel delivery going to be lacking?
Modified by BokChoy at 8:24 PM 11/26/2004
Old Nov 26, 2004 | 07:37 PM
i think that with those compression numbers that is pretty much impossible to run on pump gas....thats just my opinion, and just like pirate said, you should get what you paid for, since you already payed so much.
Old Nov 26, 2004 | 10:35 PM
I would only go as high as 12:1CR (with a GOOD tune) since you will likely have to go somewhere where they do not have 93oct, if you intend on spraying then I would only go as high as 11.5.
Your stock fuel pump and rail will be fine for your setup. I don't know about the uni chip so I do not know if you can retune it for larger injectors but at I'd get least OBD1 H22 injectors (345cc/m) to prevent you from going lean up top.
Pirate
Old Nov 27, 2004 | 11:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PirateMcFred &raquo;</TD></TR><TR><TD CLASS="quote">Your stock fuel pump and rail will be fine for your setup. I don't know about the uni chip so I do not know if you can retune it for larger injectors but at I'd get least OBD1 H22 injectors (345cc/m) to prevent you from going lean up top.
what size are the h23's? 250cc?
Old Nov 27, 2004 | 03:31 PM
Default Re: 13:1 H23 (hOndafienD 04)
235cc
Old Nov 27, 2004 | 09:06 PM
yeah its still a big difference, and might make all the differance in the world at top end...
Old Nov 27, 2004 | 11:38 PM
jdmHboy's Avatar
YOu are definitely going to need Hondata or something to tune it with.
Old Dec 12, 2004 | 04:37 PM
bump for an update
Old Dec 12, 2004 | 06:07 PM
JDogg's Avatar
13:1 is fine as long as you have a good tune... big combustion chamber/bore will let you do that.
Old Dec 12, 2004 | 06:25 PM
Default Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">13:1 is fine as long as you have a good tune... big combustion chamber/bore will let you do that.</TD></TR></TABLE>
how big of a bore are we talking? 87mm, 88mm?
Old Dec 12, 2004 | 06:48 PM
TorganFM.'s Avatar
Non-vtec, right? Ever considering going carb'ed?
Old Dec 12, 2004 | 06:49 PM
yup non vtec....would that be possible? hmm...this is getting intresting...
Old Dec 12, 2004 | 06:56 PM
JDogg's Avatar
87 is big.. at least for a honda
