venom cam gear settings
just installed venom cam gears on the gsrx (b18c1) any good ideas of where to set them at? Oh yeah the car has ctr cams. thanks guys for everything.
Without a dyno, you'll really have no idea what effects the timing changes are having on the power curve, so I'd leave them at 0,0 until then. BTW - what exactly is a "GSRX"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">Go to the dyno and tune or you may end up losing power or causing damage!</TD></TR></TABLE>
every motor is different. even if you have the same set up as the another motor they are still different. spend the money and do it right. if you dont want to then you are risking you motor.
hondapowerb16a2
14
May 14, 2009 07:45 PM
