Stock Sway Bar Sizes
Hey H-T,
I've been compiling a list of stock sway bar sizes for Honda / Acura's:
http://grabka.org/articles/hondaswaybars.php
... but I need sizing information for the 92+ Civics. If anyone has that information, post it here!
Also, if you see any errors in that list, please let me know.
dg
dg
really? from what I can tell, ALL 92-95 civic's had a 21mm front sway:
http://www.hondaautomotivepart...R+ARM
Looking this **** up is hard work
92-00 civic ex has 22mm front sway.
I think that 92-00 civic lx also has 22mm front sway.
92-95 civic si had 22mm front sway
99-00 si had 26mm front sway, 13mm rear sway
No 96-00 civic (except si) had a rear sway. I believe the same is also true for 92-95.
Slightly bigger?!! Did you know that even 1mm thicker is a big difference?
While 26mm is huge and great for reducing body roll, many feel that it is too large and it makes it difficult to tune the suspension for neutral handling given the rates of the majority of aftermarket springs and swaybars. I haven't seen any rear solid swaybars thicker than 22mm as that thickness already poses a problem for the rear subframe. You could choose your own custom spring rates, but if you're at that level you're probably not using a front swaybar at all.
26-24-22-21mm front sway for street driving and autoX =
26-24-22-21mm front sway for racing =
no front swaybar + very high front spring rates for racing =
no front swaybar + very high front spring rates for street driving and autoX =
with the 26mm bar, the idea is to support the added weight of the B16 and associated accessories. but when it comes to daily driving dynamics, the 22mm is totally fine, even for the B16-equipped cars, and a larger rear sway bar is desirable..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">"Civic 88-91 17.0mm 13.0mm"
this isnt true.</TD></TR></TABLE>
"Civic (Si) 88-91 18.0mm 15.0mm"
This is great general info, and I'm sure most of it IS right. But I just removed and measured the OEM swaybar from my '89 Civic Si, and while I've read elsewhere that 15 mm is the diameter on the 4th gen Si models, mine reads 0.52" with my micrometer, which is like 13.2 mm, so I'm thinking my car somehow got the non-Si bar . . .
I suppose it's possible they threw the base model bar on there by mistake, or maybe they just ran out of the correct, larger Si bar that day in the factory, but that seems really odd for Honda.
tells you the sizes at the bottom of all gens including dc/eg
http://www.jdmuniverse.com/forums/view_ekswaybars.html
