JDM Clutser Conversion
i just ran across this site by accident. appearently these people make a converter that plugs into the VSS line and some how tricks somthing into making ur JDM gauge cluster read those KMH numbers as MPH numbers. i was reading SPORT COMPACT CAR (the one with BRIAN SPILNER aka PAUL WALKER's) and i saw this skyline that read in MPH even those ther number were in KMH. not sure if it is easy to follow what im saying to ill break it down a little bit easier. Ok say u have a jdm clutser and ur driving down the road at 80 KMH, ur not going 80 mph. but with this converter if ur cluster said 80 kmh you would be really going 80 mph. understand? well here is the site http://www.kilburne.com/2410/frames.php just curious if maybe someone has done this before and i missed it when searching or if someone has used them and kept it a secret from the rest of the HT world. well this just locked my into buying a jdm cluster. that is all.
never did that but if you look in my sig. you can see what i did to a jdm itr gauge. you can get a jdm black eg gauge cluster and then just swap out the speedo with a usdm one. but most like the white gauge faces so i guess the only option is that converter.
TurboEH2
29
Dec 1, 2004 05:39 PM
virginia_dude
Feb 1, 2004 11:53 AM
