stock shocks? or tokico blues
Old Nov 26, 2004 | 12:31 AM
G2Crash's Avatar
Default stock shocks? or tokico blues
I have Skunk 2 coilovers, and I have stock shocks or tokico blues, I'm suspension illiterate so I've gone by rumors and not many people like tokico blues. and I'm just running this setup till I can afford an adjustable strut. tia
Old Nov 26, 2004 | 02:57 AM
Outkast95LS's Avatar
Default Re: stock shocks? or tokico blues (G2Crash)
Tokico blues are stiffer than the stock shocks, but either or, the shocks are gonna blow soon. Skunk 2 coils have a very high spring rate (500+ right?), and you must run a strut that can handle those rates. Tokico illuminas, Koni Yellows and Kyb AGX are some options you can look into.
Old Nov 26, 2004 | 03:31 AM
furious94ls's Avatar
Default Re: stock shocks? or tokico blues (Nine5IntegraLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine5IntegraLS &raquo;</TD></TR><TR><TD CLASS="quote">Tokico blues are stiffer than the stock shocks, but either or, the shocks are gonna blow soon. Skunk 2 coils have a very high spring rate (500+ right?), and you must run a strut that can handle those rates. Tokico illuminas, Koni Yellows and Kyb AGX are some options you can look into. </TD></TR></TABLE>
Agreed.
Old Nov 26, 2004 | 04:07 AM
weedman's Avatar
Old Nov 26, 2004 | 02:19 PM
G2Crash's Avatar
alright that sounds good. I'm going to replace them sometime down the line, but like I said don't have the cash at the moment so I'll give it a month or two. thanks for the info.
Old Nov 26, 2004 | 02:50 PM
b18vtek's Avatar
My friend has a set of tokico blues in his 03' SI and doesn't have anything bad to say about them. He actually saved some dough because stock struts were more money then the aftermarket struts for his SI. Just a lil bit stiffer which is better IMO.
Old Nov 26, 2004 | 02:56 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: (G2Crash)
Geo Metro or 645ci?
Old Nov 26, 2004 | 03:04 PM
G2Crash's Avatar
lol, alright, sounds good to me.
Old Nov 26, 2004 | 04:16 PM
jdm_lover's Avatar
hahah...well i think both arnt worth it...i would rather get koni yellows...cause they are the shiea...well tokicos i had for a yr and they died ...so konis id perfer....they still riding strong...koni yellows...
Old Nov 26, 2004 | 07:54 PM
G2Crash's Avatar
well, I have a problem, I just took one of the struts off the spring, and with my hand I compressed the strut and I can hear a sqeak sort of noise, sounds as if air is escaping a little bit. but it's very faint. I assume the struts will need to be replaced...any thoughts?
Old Nov 27, 2004 | 02:16 AM
Usually if a shock is blown, there would be some sort of oil leaking from the piston. Also another test is, press down on the shock,and see how stiff the rebound is. If there is absolutely no pressure, then its blown
all-mtr-teg
Suspension & Brakes
10
May 18, 2007 01:43 PM
96WhiteOnBlack
Mar 19, 2007 09:09 PM
tommysusu
10
Oct 12, 2004 06:45 PM
FkingSUV
Mar 9, 2004 07:41 AM
shattergsr
Sep 12, 2002 05:39 PM
