start of rust. some help needed.
Old Nov 25, 2004 | 06:48 PM
GreenMachineRex's Avatar
Default start of rust. some help needed.
well my crx is rustless. well i thought it was. i can see some forming of rust on one of my 1/4 panels on the 'lip' on the inner side.
now can i do something to it before it gets bad? any products? sanding? etc? thanks!
Old Nov 25, 2004 | 07:54 PM
92integra_gs's Avatar
sand it out to bare metal , use rust inhibitor... and then clean it out again... and use primer.. and some under coating in there...
here a good tip start to pressure wash your car especially under the fenders and rear 1/4 at least once every 2 weeks.. or when ever you wash your car the more frequent you are the better.... HTH
Old Nov 26, 2004 | 05:25 AM
mrspeaker's Avatar
Default Re: (92integra_gs)
You should have taken off that rubber lining that goes around the lip of the 1/4 panel..
And clean the dirt/rocks out of the pockets in the 1/4 panel..because if you dont the water will just sit there and rusts the metal away..
Old Dec 2, 2004 | 12:31 PM
GaRn's Avatar
Default Re: (Mrspeaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker &raquo;</TD></TR><TR><TD CLASS="quote">You should have taken off that rubber lining that goes around the lip of the 1/4 panel..
And clean the dirt/rocks out of the pockets in the 1/4 panel..because if you dont the water will just sit there and rusts the metal away..</TD></TR></TABLE>
that doesn't do any good when its been there for 15+ years, the rust was already well on its way..
btw I just found a spot on my lude today.. ****** bullshit.
WhiteOnRice
Paint and Body
Sep 8, 2007 05:29 PM
NoPainNoGain
Honda Civic (2006 - 2015)
May 28, 2007 03:38 PM
triple999
Oct 29, 2006 05:10 PM
team808
Jun 24, 2006 01:41 PM
CRX MASE
34
Mar 31, 2006 07:42 PM
