MIG welding wire for aluminized steel tubing
Old Nov 25, 2004 | 04:27 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default MIG welding wire for aluminized steel tubing
sorry, the search function is broken and I havent been able to find anything-
Im sure this has probably been covered, but I plan on welding some aluminized steel exhaust tubing together. the MIG wire we have on hand is what we use for welding galvanized steel, I was wondering if that would be acceptable.
not exactly sure what aluminized steel is (is it just surface treated steel?) or have they altered the composition of the steel? if its just a surface treatment, then I presume the wire I have will work fine.
if I cant use the wire I've got, I would sincerely appreciate it if someone could tell me what kind I need, or at the very least, point me in the direction of a guide (or book) that would cover what Im looking for and hopefully be able to answer any questions I might have on MIG welding in the future.
Thanks in advance, guys
Old Nov 26, 2004 | 08:56 AM
95db8GSR's Avatar
Default Re: MIG welding wire for aluminized steel tubing (tharptroy)
aluminizing is just a surface treatment, so the wire you are using on the galvanized steel will work fine on the aluminized steel. you may even find that it tends to weld cleaner and with much less fumes than galvanized.
batboyvaj
Welding / Fabrication
Jan 16, 2008 02:20 PM
FastCougar
Nov 27, 2006 03:14 PM
C_H_A_D
42
Aug 31, 2006 04:21 PM
fastcivicboy
Feb 19, 2005 01:02 PM
Greaser
Mar 17, 2003 11:09 AM
