SWAY BAR WORTH IT?
i have a 94 del sol s model with a stock front sway bar. Would upgrading to a suspension technique sway bar actually help or just waste of money?
Well technically you don't want a front sway just a rear. It also depends on what you want to accomplish with your car. Hondas have understeer so with stiffer suspension in the back, then you will create oversteer which most people prefer. So a sway bar in the back would be well worth it, but not so much in the front. It's all based on what you like though.
U can buy both front and rear sway bars as a package (suspension technique) at a discounted price, i would say its worth it, but compare the size of your stock front to the aftermarket to see if there is a big size difference.
