Wiring to harness? which one?
Old Nov 25, 2004 | 03:09 PM
DaMmniTz's Avatar
Default Wiring to harness? which one?
Hi people. As you all know, 88-91 Crx have two stock fans on the radiator to cool it off. My fans have the wires cable to the fan but it doesn't turn on. Do i need to connect it up to somewhere? I don't think it has power to the wires. Cause when i place a Double AA battery to the negative and the positive side. it turns on. But when i don't have the double AA batteries, it won't turn on. How can i connect this so that it work when the radiator is hot? . . . I tried hooking the negative to the negative wires on the battery of the car and the other blue wire to the positive battery of the car . . and this turns on the fan even when the car is OFF. LOL so can't do it that way. Any suggestion?
Old Nov 25, 2004 | 03:54 PM
rjay8604's Avatar
Default Re: Wiring to harness? which one? (DaMmniTz)
You are probably messing with the AC fan, which is for the AC condenser not the radiator so it works independently of the cooling system.
slow_low_eddie
Apr 30, 2014 07:07 AM
SumOne
Oct 23, 2006 01:14 PM
B18OnTop
Mar 11, 2005 06:23 PM
spettinger
Jun 22, 2002 02:05 PM
