question installing jdm 1 peice headlights for g2 integra
Old Nov 25, 2004 | 01:35 PM
djay86's Avatar
Default question installing jdm 1 peice headlights for g2 integra
I'm about to install my headlights and i have a few questions i thought you guys may be able to help me with as i know there are alot of g2 guys lingering this forum.
Are you headlights supposed to come with the rubber strip around the corner lights? Mine did not, and I tried getting them off my old ones but they were kinda rotted apart. I do have access to a parts car and hopefully I will be able to get them.
On the car, there are 4 plugs for each side. 1 corner light, 1 unknown, the main bulb, and this little 2 prong connector.
On the JDM headlights there are 3 places for wires. I know that the main bulb must be cut and wired up to the stock harness, but what about the other ones? Do the plugs just slide in?
I know this sounds confusing, so if you guys dont understand, ill try to be more clear about it...
Old Nov 25, 2004 | 02:07 PM
blk_db2's Avatar
Default Re: question installing jdm 1 peice headlights for g2 integra (djay86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 &raquo;</TD></TR><TR><TD CLASS="quote">
Are you headlights supposed to come with the rubber strip around the corner lights? </TD></TR></TABLE>
yes there is suppose to have that rubber strip there, but as long as it sealed, you won't need its...
On the car, there are 4 plugs for each side. 1 corner light, 1 unknown, the main bulb, and this little 2 prong connector. </TD></TR></TABLE>
there is only 3 plugs..... 1 corner, 1 main (h4h bulb) and 1 fog light, that 2 prong connector...
On the JDM headlights there are 3 places for wires. I know that the main bulb must be cut and wired up to the stock harness, but what about the other ones? Do the plugs just slide in? </TD></TR></TABLE>
match the wires up even for the fogs..... check out teg tips on http://www.g2ic.com
Old Nov 25, 2004 | 10:54 PM
djay86's Avatar
Default Re: question installing jdm 1 peice headlights for g2 integra (blk_db2)
isnt there actually 2 plugs on the car harness for the USDM corner? why is this?
Old Nov 26, 2004 | 12:01 AM
Slain's Avatar
usdm has a flashing bulb and one that stays on constant. i just used the one that stays on constant as i have bumper lights that flash already and tuck the spare harness away
Old Nov 26, 2004 | 12:47 AM
importdude2000's Avatar
i have a shitload of rubber seals that go on top of corner lights...
$2 a peice let me know
Out of the 2 stock plugs only one will fit
if you go by that
On the jdm light Your lights will only be on /IT WILL NOT FLASH
If you want it to flash/be on
You gotta cut the wires and swap the Sockets
easy stuff
considering i installed about 4 cars
and sold many sets of 1peices
Old Nov 26, 2004 | 09:46 AM
Robstunner4's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">usdm has a flashing bulb and one that stays on constant. i just used the one that stays on constant as i have bumper lights that flash already and tuck the spare harness away</TD></TR></TABLE>
Ditto, but i use the flahing on, and leave that constant one hanging.
Old Nov 26, 2004 | 10:21 AM
93GSRB17's Avatar
Default Re: (importdude2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importdude2000 &raquo;</TD></TR><TR><TD CLASS="quote">i have a shitload of rubber seals that go on top of corner lights...
if you go by that
easy stuff
just curious. how much for a set?
Old Nov 26, 2004 | 06:18 PM
integraXTC's Avatar
damn, I never knew that. Now I know. But the previous posts make it sound like they're interchangeable *w/0 mod*
Old Nov 27, 2004 | 07:59 AM
JustinG60's Avatar
Default Re: (93GSRB17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93GSRB17 &raquo;</TD></TR><TR><TD CLASS="quote">
just curious. how much for a set?</TD></TR></TABLE>
how much for a set of 1 pieces? $149... (www.hmotorsonline.com)
Old Nov 27, 2004 | 09:58 AM
jdm supplier onyl has 1 side now
so i dont sell it anymore..
but usally 129+ship at pjdm
on ebay too
around 140-50 shiped usally
but there not guarentee clear like mines
if you have anymore questions you should ask me
i know the da jdm 1peice likes its my body
Old Nov 27, 2004 | 01:28 PM
djay86's Avatar
here she be............
Camera doesn't do any justice. The lights are much nicer than USDM stock, and the fogs are very noticable yellow bulbs. I really like them. The main bulb wiring was easy, but i became a bit confused about the corner/ ****. Luckily I had a friend that swung by and helped me out.
Thanks for the help guys!
Old Nov 27, 2004 | 02:55 PM
mr.beeks's Avatar
Default Re: (djay86)
the only tedius thing is the little square in the fog lights.
but im prety sure you know how to remove it.
Old Nov 29, 2004 | 11:22 AM
Default Re: (mr.beeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.beeks &raquo;</TD></TR><TR><TD CLASS="quote">the only tedius thing is the little square in the fog lights.
but im prety sure you know how to remove it.</TD></TR></TABLE>
with a heat gun, its really easy
but yeah, it looks alot better without the glare gaurd, and i never got pulled over for it, so i think its ok, unless ur in CA. i opened it up twice, once to paint it black on the inside, and then another time to paint it back to chrome (i didnt like the black)
Old Nov 29, 2004 | 07:11 PM
integraXTC's Avatar
so removing the glare guard will blind oncoming traffic?
Old Nov 29, 2004 | 08:19 PM
racinategra's Avatar
Anyone else out there do HID conversions on the JDM one pieces? I just did it! BUMP for HIDs! I had to convert mine to regular H4 to accomodate the HID bulb. Is there another way?
Old Nov 30, 2004 | 08:02 AM
Default Re: (racinategra)
i dunno if they blind them, im dropped 2.5 in the front, so i doubt it even makes a difference, but yeah, they are alot brighter, and looks better than without that nipple. did you do the fog-light trick, where you could turn the fogs on w/o having the headlights on?
Old Dec 1, 2004 | 12:26 PM
integraXTC's Avatar
I think you're talking to me Rob, if you are, then yeah, I rewired my fogs and put in the legend yellow bulb covers. I don't have one pieces yet
silverbullet5410
Mar 13, 2012 11:57 AM
jdm93cx
Honda S2000
Oct 19, 2005 09:43 AM
philosofy1
May 3, 2005 03:17 PM
crxgator
12
Nov 23, 2003 11:45 PM
EndlessGarageEG6
Jul 12, 2002 07:24 PM
