in need of help
Old Nov 25, 2004 | 12:55 PM
cdn_cd5's Avatar
Default in need of help
i have just recently changed the driverside drive shaft because it sounded like ****. it still makes the clicking noise. Could it be the other drive shaft or something much worse? Plus the clicking sound it makes now is much worse and is all the time vs. before i change the drive shaft, it would click only turning. Could it be something wrong with the steering column ???
thanks for any help ppl!
Old Nov 25, 2004 | 01:23 PM
fsufan814's Avatar
Default Re: in need of help (cdn_cd5)
sounds like a couple possibilitys, first off did you replace it with a new axle? bc it sounds like you just put in another broke one, also i would replace the other side just bc it makes sense to do them both at the same time, i would suggest you check the upper and lower ball joints for unwanted shifting or moving, and or the actually lower control arm bushings, i would also look at the tie rod ends
e.
SIDreamer
Feb 24, 2011 09:27 AM
spoonracer84eg
Suspension & Brakes
Dec 4, 2005 06:12 PM
Doubledeala
Jan 29, 2005 12:14 AM
