b18b1 into 91 CRX Si. Need some more info.
I have searched and found most info., however, I still have a few uncertainties. (find lots of contradicting info.)
I have the obd2 harness so i was going to cut and solder plugs to my si harness. Where can i find a wiring schematic for a crx si?
I know i need to swap to an obd0 distributor, do i need to do anything with the crank trigger on the b18?
I have done numerous swaps just never put an obdIIb into an obd0 car and wanted to check the needs of wiring.
I have found few to no post on obdIIb motor in obd0 car?
Thanks for your help.
Modified by Jester_Si at 10:23 PM 11/25/2004
if you are going to use a obd-0 dizzy you should go obd-0 wiring.... meaning you got to convert from obd-2 to obd-0... IMO you best opt is to get a obd1 92-93 PR4 integra dizzy... and convert from obd-2 to obd-1 w/ the harness conversion.... obd-2 to obd-0 is just hard and time consuming conversion.. but let me remind you it can be done...
sig has link to wiring schema. the manual.
edit: aw the old UK manual site finally died. my bad,
http://www.honda.co.uk/owner/CRXManual/
nifty lil html/adobe version.
onekoop
Dec 5, 2004 03:26 PM
BoRiCuA
Aug 25, 2004 04:57 PM
89 JDM CRX
Mar 21, 2004 01:49 PM
