FS: 1990 CRX Si (maryland east coast)
i have a 1990 CRX Si that i just crashed recently~ its completely stock with about 195K miles on it.
the rear tire blew out at about 50 mph, i lost control and hit the concrete barrier with the front passenger side of the car. the damage is all to the passenger side, and is as follows:
- bent lower control arm
- bent swaybar
- bent axle
- bent tie-rod end
- cracked rear crossmember
- broken radius rod
- cracked passenger side quarter glass
- cracked headlight
- cracked corner light
- dented fender
- scratched door
- scraped bumper
- cracked rotor
i started the engine after the accident, and it is in good running condition, but i snatched the distributor off to put on my other crx. this would be an excellent car for someone with time to replace the parts, or someone who needs a parts car. the whole interior will be included, minus the radio. the sunroof is in good working condition and the bumper has working fog lights.
i will let the car go as is for $600. this includes everything shown in the pictures (which i havent posted yet). i had planned to replace the entire rear crossmember, rack/pinion, tie-rod ends, lower control arms, and swaybar, but i never got around to it. i have all the things mentioned though, and if you want to piece the car together, ill let it go for $800 with all those parts.
car is located in maryland, and will need to be towed.
* pics will be up later tonight *
e-mail: dmin2684@yahoo.com
- bent swaybar
- bent axle
- bent tie-rod end
- broken radius rod
- cracked headlight
- dented fender
- scratched door
- scraped bumper
- cracked rotor
PICS~!
Massive rust spot on passenger side rear quarter panel
Bent suspension
Cracked glass
Rust on drivers side door
Small bubbling on drivers side rear quarter panel
Cracked rotor
Bent suspension
Cracked glass
Cracked rotor
bump for you
lost my whole tire / rim once on the back left side of my crx while doing 80.. not much happened besides a few snapped bolts, but it coulda been much worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jginter »</TD></TR><TR><TD CLASS="quote">Iwas wondering if you would want to get rid of the right rear lower conrol arm?</TD></TR></TABLE>
not parting it out jus yet...i know someone wants to take it off my hands!
