someone help (door)
Old Nov 25, 2004 | 12:21 PM
Bone Stock's Avatar
From: City of fakeJDMs but their vT3s HiT H3ll4 L0uD...., usa
Default someone help (door)
iight guys i took the door opener thing off and now im trying to take off the silver part where you pull it to open the door. Im stuck i dont know how to take it off. I took off the unlocking thing, but the silver door opener i cant do it. can someone help me.
BTW: 94 LX
Old Nov 25, 2004 | 01:51 PM
bodiez's Avatar
Hit the floor!
Default Re: someone help (Bone Stock)
If you mean the piece of hooked plastic on the metal piece, just push the plastic 'C' backwards until the metal part is free then push the metal up to get it out of the hole.
Old Dec 1, 2004 | 12:46 PM
Heat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">iight guys i took the door opener thing off and now im trying to take off the silver part where you pull it to open the door. Im stuck i dont know how to take it off. I took off the unlocking thing, but the silver door opener i cant do it. can someone help me.
BTW: 94 LX</TD></TR></TABLE>I just had my door apart a couple of weeks ago (changing the actuator), but I don't understand your question.
What is a "door opener thing"?
Old Dec 1, 2004 | 04:10 PM
zumiez007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote"> i took the door opener thing off </TD></TR></TABLE>
it's called a handle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">I took off the unlocking thing</TD></TR></TABLE>
uhhh.... the handle again??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bone Stock &raquo;</TD></TR><TR><TD CLASS="quote">but the silver door opener i cant do it. </TD></TR></TABLE>
the metal rod? bent at the end like an L. It sits in the hole and the plastic piece grabs onto it. Use a screwdriver and push it off and pull the rod out from the hole.
To get the panel off you need to unbolt everything! In my 92, there is a little "cubby" under the window switch that had to be taken off to reveal a screw that holds the pannel on. Use a pry tool and go around the pannel to pop everything off.
Word of advice, proof read your work. Wait, go to school and learn english!
Old Dec 1, 2004 | 06:18 PM
sj993's Avatar
Default Re: someone help (zumiez007)
Taking the latch assembly apart is pretty easy. Do as sugguested above. The rest of the panel, there are screws here and there. Just look carefully and you will see where they are. It's very easy.
Old Dec 1, 2004 | 11:49 PM
Bone Stock's Avatar
Default Re: someone help (sj993)
gotcha thanks...
stevelive3
Sep 19, 2008 05:59 PM
callmetree19
Jun 26, 2008 04:21 PM
96teggynonVtec
Jan 7, 2007 05:07 PM
team952
Jul 21, 2005 07:24 PM
esca
Audio / Security / Video
Sep 20, 2004 02:52 PM
