euro clear corners
I remember seeing a long time ago some dude who made some clear corners id imagine this would work with corners too. Heres the basic process.
get yourself some old stock corners or buy a set off ebay. drop em in some boiling water to soften the seal, pull em out and try and pry the lens from the housing, if that dont work take a dremel to it and just be careful not to damage the housing, then just get yourself some plexiglass and drop it in the oven for like 5 min on high, keep watching it just to be safe, pull it out and it should be pretty flexible, if too flexible let it cool for a bit, if too stiff turn up the heat and drop it in the oven again. then just mold it to the corner housing let it cool for a bit, cut the pieces to size and trim, get some sealant hold the plexiglass on with clamps and vuala, euro clear corners.
DC2_R
13
Nov 20, 2001 12:08 AM
