What Oil Do You Teg Fellas Use In The Winter????
Old Nov 25, 2004 | 07:54 AM
Got Milk's Avatar
Default What Oil Do You Teg Fellas Use In The Winter????
Hey whats up i just wanted to kno what would be the best oil to use for winter time meaning the cold lol...
Old Nov 25, 2004 | 10:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (Got Milk)
Valvoline Max Life 5w30 changed about every 4 weeks or so.... 5w30 is good for pretty much all climates. If your engine burns a little oil, you can try 10w30, but only if your climate doesn't dip down below freezing.
Old Nov 25, 2004 | 11:30 AM
dick_213's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (PatrickGSR94)
10w 40 cause it freezes every once in awhile.
Old Nov 25, 2004 | 11:44 AM
Stripped Honda's Avatar
99-0104
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (dick_213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dick_213 &raquo;</TD></TR><TR><TD CLASS="quote">10w 40 cause it freezes every once in awhile.</TD></TR></TABLE>
i feel sorry for your engine if your really using 10w40
i use 5w30 honda oil
Old Nov 25, 2004 | 12:14 PM
Mar_DC2's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (Stripped Honda)
i use 10w30 just cause i burn oil. it does pretty well in utah weather, just takes a little longer to warm up, etc..
Old Nov 25, 2004 | 12:28 PM
B18OnTop's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (Mar_DC2)
I use 5w 30 but I live in AZ. It doesn’t get to cold here.
-Aaron
Old Nov 25, 2004 | 12:47 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">
i use 5w30 honda oil </TD></TR></TABLE>
Honda oil? I hope you're not paying very much for that....
Old Nov 25, 2004 | 03:22 PM
Danziver's Avatar
I use either 10w30 or 10w40 synthetic.
Old Nov 25, 2004 | 03:32 PM
.water's Avatar
5W-30 in WA....never had problem last winter
Modified by Bee8teenSee1 at 6:49 PM 11/25/2004
Old Nov 25, 2004 | 03:42 PM
dick_213's Avatar
i dont think ur as smart as you think you are.
Old Nov 25, 2004 | 03:59 PM
stasi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dick_213 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think ur as smart as you think you are.</TD></TR></TABLE>
Lol.
Old Nov 25, 2004 | 04:10 PM
wanna b R's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (stasi)
5W-30 all year round
Old Nov 25, 2004 | 06:26 PM
b-power's Avatar
mobil 1 5w-30 synthetic all year long
Old Nov 25, 2004 | 06:38 PM
HONDA RR's Avatar
i use the fully synthetic mobil 1 motor oil.
Old Nov 25, 2004 | 07:04 PM
yeegsr's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (MITSUBA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MITSUBA &raquo;</TD></TR><TR><TD CLASS="quote">i use the fully synthetic mobil 1 motor oil. </TD></TR></TABLE>
right on, K&N filter + mobil1 fully synthetic all year long....10/30...oil change periodically at 3,000 miles mark...$30bucks oil change plus filter is hella expensive...
Old Nov 25, 2004 | 07:57 PM
furious94ls's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (yeegsr)
Used year round:
94LS auto gets 5w30 Honda oil. 194kmiles
94GSR gets 5w30 Castrol GTX. 94k miles.
And of course both are used with the OEM honda oil filter.
There is no point in 10w30 because in the end it's still a 30 weight oil. So when the engine is cold your pumping a 10 weight instead of a 5 weight. For the basic I/H/C/E B18 motor stick with a good quality 5w30 motor oil with a MAXIMUM change of 3k miles. If your motor is heavily modified, then talk to your engine builder for what is best. If your motor is running shitty and smokes, use the thicker oil, and save for a re-build.
Old Nov 25, 2004 | 11:55 PM
Amkread's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (furious94ls)
mobil 1 0w20
Old Nov 28, 2004 | 09:27 AM
ejprimo's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (Amkread)
castrol syntec 0w-30 year round.
Old Nov 28, 2004 | 09:47 AM
Honda97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stripped Honda &raquo;</TD></TR><TR><TD CLASS="quote">i feel sorry for your engine if your really using 10w40
honda oil is garbage. use csatrol syntec 5W30 with fram oil filter
Old Nov 28, 2004 | 10:13 AM
Kowalski's Avatar
Mobile Drive Clean 5w30 all year round.
Old Nov 28, 2004 | 12:01 PM
importdude2000's Avatar
10w40 all year long
castrol gtx only+wix racing filter
Old Nov 28, 2004 | 12:07 PM
darkblue98ls's Avatar
I use 10w30 castrol syntec with lucus oil stabalizer. I also live in austin tx so it does'nt get that cold here.
Old Nov 28, 2004 | 12:10 PM
hmongboyLS's Avatar
red line oil 5w30 all year around here
Old Nov 28, 2004 | 01:19 PM
xiLLtegRax's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (hmongboyLS)
5 dub 30
Old Nov 28, 2004 | 02:07 PM
wall of tvs's Avatar
Default Re: What Oil Do You Teg Fellas Use In The Winter???? (xiLLtegRax)
Valvoline 5w30 Max Life with Amsoil SDF-20 filters is what I used to run in the 'teg and currently run in the 'lude.
The WRX sees Amsoil 5w-30 ASL Synthetic with an SDF-20 filter.
This is year-round in MN, btw.
