wheel hop question
Old Nov 25, 2004 | 05:10 AM
simplypinoyy's Avatar
Default wheel hop question
I know ... search function .... blah blah blah.... but rite now at 9 am eastern standard time and the search server is down or something. I had recently changed from coilovers to lowering springs... I also put some yokohama radials on the coilovers were swapped out. Now my car wheel hops.... Is it because of the lowering springs or is it because of the tire? (tire pressure - should I lower the tire pressure?)
Old Nov 25, 2004 | 05:37 AM
slambedcivic's Avatar
Default Re: wheel hop question (simplypinoyy)
full race traction bars
im guessing your car sits slightly higher now than it did with coilovers?
Old Nov 25, 2004 | 05:43 AM
Deemeetree's Avatar
Electrician
It will be hard to fully eliminate wheel hop from hard launches without using traction bars of some sort.
Old Nov 25, 2004 | 05:49 AM
Default Re: (Dimi)
well it never wheel hopped before when i had the coilovers though... u guys think that lowering the psi's in my tires work?
Old Nov 25, 2004 | 05:53 AM
Default Re: (simplypinoyy)
it can, but doesnt always work
Old Nov 25, 2004 | 05:57 AM
Default Re: (slambedcivic)
thats the only reason y i never ran my hb this summer n fall because the wheel hop was pretty bad, i never had that problem before just after i put in the new lowering springs and new tires
Old Nov 25, 2004 | 06:16 AM
maybe you need to launch better, try different ways... dont just drop the clutch, preload the transmission and then launch
Old Nov 25, 2004 | 07:23 AM
fishnfst's Avatar
When I replaced my old rubber bushings with the urethane ones it elminated most of my wheel hop problems...... I'm not making crazy power so take it for what its worth...190whp/180tq. A traction bar setup would definitely help.. How much pressure are you running in your tires right now... sub 20psi I would think huh... I guess it depends on the tires as welll Something with a higher side wall and lower pressures will also decrease wheel hop due to the a mount of sidewall flex...
Oops just reread your post... Looks like in your sig you are basically running a stock z6 I think that the urethane bushings would make a big difference in your wheel hop issues...
Old Nov 25, 2004 | 08:05 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote">
Oops just reread your post... Looks like in your sig you are basically running a stock z6 I think that the urethane bushings would make a big difference in your wheel hop issues...</TD></TR></TABLE>
Yep exactly.... I put them in my car and no longer have any wheel hop. Traction bars are nice but more expensive than the urethane mounts and you have to play with the adjustments to get them dialed in right. Unless you're a serious drag racer just stick with the poly engine mount inserts.
Old Nov 28, 2004 | 06:05 PM
92silude's Avatar
I've got a little motor work done to my lude, and it's got the stock tires...it's got mad wheel hop off the line, it's already got urethane motor mounts, so would you suggest tires or traction bars?
Old Nov 28, 2004 | 06:54 PM
TurboTagTeam's Avatar
When i had my stock suspention and wheels i had no wheel hop from hard launches. Now i have NEX coilovers and falken azanis's and my car feels like it has hydros in it. I dont even launch it anymore. Im scared of breaking and axle or a motor mount. I just ease it out of 1st then mash the throtle and im usally fine.
Old Nov 28, 2004 | 08:20 PM
skunkwhat's Avatar
Default Re: wheel hop question (TurboTagTeam)
aRe the lowering springs stiffer than the coilovers? Are you running the same struts? Did the ride height change? with the new springs?
Old Nov 28, 2004 | 10:47 PM
fishnfst's Avatar
92silude I'm talking about the urethane bushings for all of your control arms and shocks in the front not just the motor mounts...
Old Nov 29, 2004 | 12:17 AM
NikoZai's Avatar
jimfab X-member get it
Old Nov 29, 2004 | 12:21 AM
BoostedJeff's Avatar
Default Re: (NikoZai)
Traction Bars should solve
def worth the money!!
Old Nov 29, 2004 | 02:37 AM
92silude's Avatar
I've looked around for some traction bars can't seem to find any...can anyone help me out?
Old Nov 29, 2004 | 02:53 AM
TGrant's Avatar
i know g-sport makes them not sure on the quality though
loup05
Jun 21, 2010 12:24 PM
miksew
Suspension & Brakes
12
Apr 22, 2006 12:48 AM
firebane
Mar 31, 2006 06:45 PM
soon2bdropped
Mar 15, 2006 09:43 PM
Kyles ej1
Nov 16, 2004 07:35 PM
