NEED SOME ADVISE LS/VTEC OR GSR
Old Nov 24, 2004 | 11:49 PM
boostng r's Avatar
a
Default NEED SOME ADVISE LS/VTEC OR GSR
ok this is what i am working with i have a 98 ctr motor in my eg coupe the rod took a **** and put a whole in my block enought said i have not took my motor apart yet i am hopping my ctr head and pisteons are good
no here the deal
should i get a gsr bottom end and put my ctr head and my pistion in that
or should i get a ls and put my ctr piston in that and my ctr head
good help is hard to find so i turn to honda-tech thanks and what do u guys think
Old Nov 25, 2004 | 12:00 AM
boostng r's Avatar
a
6t
Old Nov 25, 2004 | 05:25 AM
prada_2o0o's Avatar
Default Re: NEED SOME ADVISE LS/VTEC OR GSR (b16coupe4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe4 &raquo;</TD></TR><TR><TD CLASS="quote">ok this is what i am working with i have a 98 ctr motor in my eg coupe the rod took a **** and put a whole in my block enought said i have not took my motor apart yet i am hopping my ctr head and pisteons are good
no here the deal
is the head off the block yet?? what kind of damage do you have internally?
Old Nov 25, 2004 | 06:33 AM
reactiondc2's Avatar
Default Re: NEED SOME ADVISE LS/VTEC OR GSR (prada_2o0o)
no here the deal
</TD></TR></TABLE>if you threw a rod chances are good that your piston is garbage
Old Nov 25, 2004 | 07:37 AM
prada_2o0o's Avatar
Default Re: NEED SOME ADVISE LS/VTEC OR GSR (reactiondc2)
the head may also be damaged. why did this rod go??? what happened? you may not be able to use the head either
Old Nov 25, 2004 | 01:49 PM
boostng r's Avatar
a
ok the head is good thanks god the pistons is also good the rod cam loose of the crankshaft one blot got loose and broke the rod in half the block looks like some one took a shotgun to it so what do u guys think gsr or ls
Old Nov 25, 2004 | 05:52 PM
boostng r's Avatar
a
Default Re: (b16coupe4)
tttttttttttttttttttttt
Old Nov 26, 2004 | 07:19 PM
DC-4-Drew's Avatar
This really is a question of personal preference and how many $$$ you want to burn. I would personally go with the LS/Vtec.
hookups214
Nov 25, 2006 03:00 PM
Rob Dizzle
Mar 1, 2004 11:30 AM
XxSOHCDriVerxX
Jul 27, 2003 06:51 PM
crxbust
Jun 13, 2003 12:40 AM
