Requesting Type-R B18cR n/a Build Advice
Old Nov 24, 2004 | 11:21 PM
Viper8L488's Avatar
Default Requesting Type-R B18cR n/a Build Advice
Hello all you motorheads. I just freshened up my 98 Civic coupe with a 1997 JDM ITR engine with the JDM LSD 4.75 tranny.
As a baseline with i/h/e, VAFC, and alum flywheel we put down 169 hp and 120 ft/lbs. (please bear in mind that it is a fully featured motor with p/s and a/c)
I am requesting advice on valvetrain components to work well with the stock bottom end and Hondata engine management. I am pretty set on Toda springs and retainers. I have personal experience tuning with Skunk cam gears and like them because they have more adj. bolts than most. I am up in the air on camshaft options. I have researched these camshafts and many others, but would like suggestions and support from you folks who have more experience with this engine. I am considering:
Skunk spec2
Toda B
Buddy Club 3.
I want to maintain good daily drivability and traffic friendliness but would like to pick up hp and tq across the entire RPM range. I would also like camshafts which would be compatible with a future bottom end build with 11.5 c/r, 84mm bore, sleeving, blueprinting/balancing. Please offer your suggestions with support (preferably from experience with this engine). Thanks!!
Old Nov 25, 2004 | 12:44 AM
Bbasso's Avatar
Default Re: Requesting Type-R B18cR n/a Build Advice (Viper8L488)
I think you would have better responses from here : https://honda-tech.com/zeroforum?id=18
.:cesar:. ELUSIVESIR
Aug 23, 2007 09:21 PM
Northern California (Sales)
22
Aug 23, 2007 10:21 AM
jdmB18CT-R
Feb 13, 2006 05:37 AM
Viper8L488
Nov 25, 2004 08:23 AM
toEknEEg
14
Nov 23, 2004 07:50 PM
