Omnipower Height adjustment problem
Old Nov 24, 2004 | 06:42 PM
aZnjCC's Avatar
Default Omnipower Height adjustment problem
Alright, this isn't really appearance, but i couldn't really think of where to put this so I could get EVERYONE to look.
I've read one or two cases on here where some people's omnipowers had the 19mm nut on the top seize on them. By seize, I dont 'mean completely lock up, but I am still able to loosen the nut if I use an allen key to hold the shaft still. Before, I could just use a simple deep socket 19mm ratchet and loosen or tighten that nut. But just a couple of days ago while i was raising the coilovers, The front passenger nut and shaft seized. It's not much of a bother to me, but it would just save me time if I could simply turn the nut without holdin the shaft in place with the allen wrench.
Has this happend to more of you out there with omnipowers? Did simply replacing the 19mm nut with a new one alleviate the problem?
Old Nov 24, 2004 | 07:46 PM
aZnjCC's Avatar
anyonez?
Old Nov 24, 2004 | 08:07 PM
ekian's Avatar
has not happened to mine but I haven't touched them/changed the height since I got them.
Ian, who's feeling a sudden urge to dump the **** outta his car.
Old Nov 24, 2004 | 08:21 PM
aZnjCC's Avatar
kinda dreadin lowering my car this weekend....
Old Nov 24, 2004 | 08:48 PM
SpdFrk's Avatar
Default Re: Omnipower Height adjustment problem (aZnjCC)
Hasn't hasn't to me. Have you tried putting some lubricant on the nut? I always put just a little on before loosening it.
Old Nov 24, 2004 | 08:53 PM
aZnjCC's Avatar
will do that this weekend
vwtohonda
Honda CR-V & Element
Jul 21, 2012 02:03 PM
justBrowsing
Honda Civic (2001 - 2005)
May 1, 2012 06:39 PM
beoy9
Suspension & Brakes
Oct 17, 2009 09:11 PM
datssoled
Suspension & Brakes
Sep 5, 2007 10:49 AM
brent_G
Feb 19, 2002 06:15 AM
