High Compression re-built LS swap with GSR tranny, linkage, mounts, everything
Old Nov 24, 2004 | 05:22 PM
Simple's Avatar
Default High Compression re-built LS swap with GSR tranny, linkage, mounts, everything
LOWER PRICE $1600 entire swap
more pics of the engine out of the car at the bottom
Specs on motor:
B18a1 block, re honed and tanked before build
Brand new B16 pistons with OEM rings (yields about 10.8:1 compression as is, 11.3:1 with a VTEC head)
b18b1 intake manifold and TB
Camo valve cover
Brand new ACL bearings
B16 oil pump
B16 oil pan
Fresh Valve Adjustment
New gaskets: Valve cover, oil pan, head, throttle body, intake manifold, MAP grommet, exhaust
New OEM plugs and plug wires
Almost brand new odb2 LS distributor re-wired to ODB1
New cap and rotor
95 GSR transmission with 80k
New B16 clutch, pressure plate, and flywheel
New MAP
new TPS
DX harness (can include VTEC harness for those who want to do LS/VTEC)
1 new 1 used OEM axle and half-shaft
GSR shift linkage, with GSR shifter
LS header
New Timing belt
"JDM" mushroom res covers
All B series mounts
Shift linkage
Axles
Header (factory)
Motor has 2,400 miles on it. been limited to a civic DX ECU. so there hasnt been much abuse with the 6600 redline and low fuel settings.
looking for 1600 for the entire swap
Modified by Simple at 6:35 PM 12/30/2004
Modified by Simple at 6:37 PM 12/30/2004
Old Nov 24, 2004 | 06:09 PM
HicKs's Avatar
Default Re: High Compression re-built LS swap with GSR tranny, linkage, mounts, everything (Simple)
Selling it so soon!! lol
Great motor! honest guy! have driven runs awsome!!!!!!!!!! bump for good deal!!!!
Old Nov 25, 2004 | 08:29 AM
Simple's Avatar
Default Re: High Compression re-built LS swap with GSR tranny, linkage, mounts, everything (HicKs)
yep... ditching it for a SOHC turbo motor.... whaddoya do?
Old Nov 28, 2004 | 12:56 PM
Simple's Avatar
ttt
Old Dec 4, 2004 | 08:04 AM
Simple's Avatar
ttt
Old Dec 4, 2004 | 09:51 PM
Simple's Avatar
comming out tomarrow, need to sell for school
Old Dec 5, 2004 | 04:18 PM
Thrillhouse's Avatar
someone buy this thing its a hell of a good price, considering whats in it. free bump for the non vtec love
Old Dec 8, 2004 | 04:52 PM
Simple's Avatar
ttt
Old Dec 8, 2004 | 09:49 PM
Simple's Avatar
need money for tools to go to honda-school, buy my motor
Old Dec 11, 2004 | 10:08 AM
Simple's Avatar
up
Old Dec 12, 2004 | 07:48 AM
Simple's Avatar
reduced price
Old Dec 12, 2004 | 11:56 AM
rodvang's Avatar
would you part out? i just want the gsr tranny...would need it shipped though.
Old Dec 12, 2004 | 12:15 PM
Simple's Avatar
Default Re: High Compression re-built LS swap with GSR tranny, linkage, mounts, everything (rodvang)
lots of intrest in the tranny. if no-one picks this up as a complete within the next 2 weeks, ill part it out
Old Dec 13, 2004 | 03:08 PM
mattssi's Avatar
What all do you have for your sohc turbo setup? I am looking to go b series, and i have almost a complete Sohc setup? lets talk. I have some moolah too.
Old Dec 13, 2004 | 03:11 PM
mattssi's Avatar
Default Re: (mattssi)
get my number frim thomas if you are interested.
Old Dec 13, 2004 | 03:54 PM
Simple's Avatar
will do! im kinda trying to sell everything to get money to pay for tools and tuition to go to tech school... btw, i need that cluster, i have the prop valve... ill call you later tonight im sure
Old Dec 15, 2004 | 07:13 PM
Simple's Avatar
up top
Old Dec 17, 2004 | 04:21 PM
Simple's Avatar
lowed price, agian. FIRM on this one, its what i have INTO the motor
Old Dec 18, 2004 | 03:42 PM
Simple's Avatar
up up up
Old Dec 19, 2004 | 05:26 PM
antiJDM's Avatar
you still have this in your car?? i may be interested after xmas...
Old Dec 20, 2004 | 12:44 AM
Simple's Avatar
Default Re: (2thousandcivic)
nope, i swapped in a DX motor... its out and ready to go
Old Dec 21, 2004 | 06:01 PM
Simple's Avatar
up
Old Dec 27, 2004 | 09:01 AM
INTEGRAGATED's Avatar
how much for the tranny shipped to 01106??...let me know
Old Dec 29, 2004 | 04:17 PM
Simple's Avatar
Default Re: High Compression re-built LS swap with GSR tranny, linkage, mounts, everything (INTEGRAGATED)
not parting out just yet...
Old Dec 30, 2004 | 05:33 PM
Simple's Avatar
heres pics of it out, anyone give me 1600 for it?
