? about ohms to injectors.
Old Nov 24, 2004 | 04:53 PM
grimald's Avatar
Default ? about ohms to injectors.
I am only getting 7.3ohms to my injectors, I should be getting 10. What might my problem be?
Old Nov 26, 2004 | 04:38 PM
oldguy03's Avatar
It may not be a problem at all. What kind of meter did you use. Before you measure the resistance, touch the two contacts together to see if there is resistance in the meter itself. I have a cheap little meter that reads several ohms with nothing attached. Are all injectors the same? I wouldn't worry about it unless there are other symptoms.
SiRkid
Oct 21, 2003 09:53 AM
