tuning the engine.
Old Nov 24, 2004 | 03:36 PM
uniqueX's Avatar
Default tuning the engine.
How can i tune my b18b1. the motor can only go up to 3000 RPM and it stops there, so how can i fix that?
Old Nov 24, 2004 | 04:55 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: tuning the engine. (uniqueX)
How does it "stop"?
Old Nov 24, 2004 | 05:00 PM
Kendall's Avatar
Does it bog? Does it shut off? We need more details.
And regarding tuning, you'll need to invest in some form of programmable engine management.
Old Nov 24, 2004 | 06:22 PM
hondaguyef's Avatar
Default Re: (Kendall)
Sounds like "safe mode" to me. Give some more details so that we may further assist you.
Phil
Old Nov 24, 2004 | 09:33 PM
hybrid_vtec's Avatar
Is your ECU chipped?
Old Nov 29, 2004 | 07:48 AM
uniqueX's Avatar
Default Re: tuning the engine. (hybrid_vtec)
Yes, my ECU is chipped.
uniqueX's Avatar
Default Re: tuning the engine. (LSVTEC 91 Civic)
When it hit 3000 RPM it just bog and it won't go no more.
Old Nov 29, 2004 | 07:50 AM
uniqueX's Avatar
Yes, when it hit 3000 RPM it just bog and it won't go no more. The engine doesn't shut off or anything like that.
uniqueX's Avatar
Default Re: (hondaguyef)
The motor bog rite at 3000 RPM, but the motor still runs.
Old Nov 29, 2004 | 07:59 AM
drdisco69's Avatar
Default Re: (uniqueX)
Your chip is probably fucked up. Put the stock program back in if you can. It sounds like you're in limp mode, which is not fun. This is usually caused by internal ecu failure of some sort, and chipping an ecu with an unknown program is a good way to make the ecu go screwy.
What is done to the motor that makes it neccisary to tune it?
Old Nov 29, 2004 | 08:30 AM
uniqueX's Avatar
Default Re: (drdisco69)
so if i put the stock ecu back in it should go past 3000 rpm without bogging. rite.
Old Nov 29, 2004 | 10:04 AM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uniqueX &raquo;</TD></TR><TR><TD CLASS="quote">so if i put the stock ecu back in it should go past 3000 rpm without bogging. rite.</TD></TR></TABLE>
It's somewhere to start. Check it and see what happens.
Old Nov 29, 2004 | 10:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Your chip is probably fucked up. Put the stock program back in if you can. It sounds like you're in limp mode, which is not fun. This is usually caused by internal ecu failure of some sort, and chipping an ecu with an unknown program is a good way to make the ecu go screwy.
What is done to the motor that makes it neccisary to tune it?</TD></TR></TABLE>
Yes that is what I think! You can cut the J1 jumper on the circuit board to set you back to the factory program! For pics of this check out http://www.hyperducktuning.com to see pics of your ECU so you can set it back to factory settings and see if that works!
Old Nov 29, 2004 | 10:07 AM
Default Re: (hybrid_vtec)
What ECU do you have?
elliascool
May 4, 2011 04:54 PM
loner714
Feb 26, 2007 04:54 PM
chuniepatuni
Sep 5, 2006 09:47 PM
SiRex91
Apr 13, 2003 05:06 PM
Ex-ITR5874
Mar 29, 2003 11:02 AM
