Grippy tires
Old Nov 24, 2004 | 02:48 PM
vrrodri's Avatar
Default Grippy tires
I have some Kumho Ecstas in my hatch that I will need to replace in 3 months. Question is, does anyone recommend tires that will have the same great traction but with less noise? These tires are great but they are loud on the highway!
thanks
Old Nov 24, 2004 | 02:54 PM
AnToNy's Avatar
Default Re: Grippy tires (vrrodri)
Yoko AVS Es100's. Pretty good tires and not loud. I got 195/50/15's they stick very well.
Old Nov 24, 2004 | 02:56 PM
undertheradar's Avatar
Default Re: Grippy tires (jaedaSC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaedaSC &raquo;</TD></TR><TR><TD CLASS="quote">Yoko AVS Es100's. Pretty good tires and not loud. I got 195/50/15's they stick very well.</TD></TR></TABLE>
ditto....but I have 195/55/15's. I wanted a little bit more sidewall to help with the shitty freewway I commute on. Best tires I've ever owned.
Old Nov 24, 2004 | 03:07 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Grippy tires (undertheradar)
I have the Falken Azenis tires and find them to be quite sticky but not noisy on the road, 205/50/15.
Old Nov 24, 2004 | 03:08 PM
AzntaggeR's Avatar
TSPeed Factory
which kumhos did you have? i had both the 711s and 712s and had no problem with either.
Old Nov 24, 2004 | 03:09 PM
Kendall's Avatar
For what they are, the AVS ES100's are damn good. Of course there are stickier tires, but they last a good while, aren't loud, provide good wet traction, and are dirt cheap.
Old Nov 24, 2004 | 03:27 PM
Marauder's Avatar
Default Re: (Kendall)
What size rims?
I got a set of Azeni's for my teg since I have the stock steelies.
Old Nov 24, 2004 | 03:34 PM
project-boosteD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">For what they are, the AVS ES100's are damn good. Of course there are stickier tires, but they last a good while, aren't loud, provide good wet traction, and are dirt cheap.</TD></TR></TABLE>
true that
i've also tried dunlop sp sports fm901's.....205/45/16......sticky...quite....and they dont make any noises when u burn 'em either ...definite plus when ur tryin to be secretive about it haha
Old Nov 24, 2004 | 09:10 PM
skunkwhat's Avatar
Default Re: (gsrcivic147)
had the 712's on my 93 hatch and 89 toyota truck both 195/50/15, good for the money, good wet as stated above. currenty have 205/50/15 azenis on the car, seem to be pretty sticky but as stated wear faster, than es 100's or 712's
The truck has 205/50/15 es 100's they are comparable to the 712 in my opinion just a little softer. for the price(tirerack) in 195/50/15 you cant beat the es 100's
So as you can see i pretty much agree with what everyone else says
Old Nov 24, 2004 | 09:25 PM
b1ackc1v1c's Avatar
Default Re: (skunkwhat)
Yokos es 100s get some bfg drag radials
Old Nov 24, 2004 | 10:41 PM
Btech0's Avatar
Default Re: (b1ackc1v1c)
Seems like all tires that make noise are the good ones the Falken beta 451 are good but if you want something that hooks in wet or dry weather try the Yokohama A032 we carry those at Discount Tire. But also the post that are above are good tires would definitely recommend
Old Nov 25, 2004 | 01:18 AM
Outrun's Avatar
Default Re: (Biotech0123)
ES100s are overrated, but this is coming from my experience with them while hotlapping.
If treadlife is no object, then try Bridgestone Potenza S-03. The Toyo T1-S (which I feel are better than the ES100s) are just as good in the wet as S-03 and should last a tad longer in similar conditions. Another alternative is the Goodyear Eagle F1 GS-D3.
But if all you do is daily drive with little to no track/Solo time, the ES100s should suffice.
The above is based on 195/50-15 tires.
Old Nov 25, 2004 | 01:47 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (Outrun)
when i had my potenza s-03s i liked those too.
Old Nov 25, 2004 | 02:05 AM
CivicESi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun &raquo;</TD></TR><TR><TD CLASS="quote">ES100s are overrated, but this is coming from my experience with them while hotlapping.
But if all you do is daily drive with little to no track/Solo time, the ES100s should suffice.</TD></TR></TABLE>
definately agree, Kuhmo and the ES100's are both budget tyres in the uk, infact my mates over here nickname the 712's 'ditchfinders To be fair we get a lot more wet/cold weather over here, so tyres are Sooo much more important. But they are always the only thing holding you on the road, so always the most important bit on the car, so always spend as much as you can
I am running T1-S at the moment, good, but not a patch on the F1's and S0-3's, but even they cost me $450 and i get through 2 sets a year But they are 100% worth it, even more so when you have decent twisty roads and wet roundabouts to enjoy
But already the T1-S have saved me $$$ due to stopping quicker, gripping better or not aquaplaining when needed, and they give you more confidence and a higher saftey margin, and there isnt a $$ for that
Modified by CivicESi at 5:14 PM 11/25/2004
Old Nov 25, 2004 | 02:15 AM
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: Grippy tires (00Red_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">I have the Falken Azenis tires and find them to be quite sticky but not noisy on the road, 205/50/15.</TD></TR></TABLE>
werd. sticky as hell. mine are pretty much worn out but still grab better than my toyo proxes 4s ever did.. but yeah they're a little LOUD and I have 195/60/14...
Old Nov 25, 2004 | 04:52 AM
chris_c's Avatar
Default Re: Grippy tires (syntax_error)
another yoko es100 user here. decent tires i'd say. def. loose some of their grip after being heat cycled a bunch of times but damn they are cheap and work well in the rain too...
Old Nov 25, 2004 | 07:26 AM
Triscuit's Avatar
you should try some Falken ziex ze512 they're a really good tire
Old Nov 25, 2004 | 09:11 AM
eg9ferio's Avatar
From: huggin a corner in the right coast, PA, United states
Default Re: (Ronin EG6)
yea,falken ziex are nice tires but not quite as sticky as the azenis ....but still good tires...
Johnoolo
Dec 1, 2013 09:13 AM
chikihopper
Wheels
Aug 8, 2008 06:00 PM
doubleshotz
Oct 4, 2007 05:48 AM
ej1 assasin
Nov 22, 2006 07:36 PM
Curtisbeef
Aug 12, 2005 05:53 PM
