Need help with JRSC on B20VTEC in a crx
A buddie on mine has a JRSC for a gsr. Are the runners the same on a b16a and a gsr head. Would the JRSC go onthe head and do u thank there would be enought room for the pully.
Thanks alot,
Chris
Thanks alot,
Chris
The B16a and Type R head are not the same bolt pattern as the GSR. You can switch manifolds and then it will fit the head. With a little modification it will fit in the CRX.
Take a look on our site , It may give you some ideas.
http://www.lhtperformance.net/....html
You can re drill the manifold but it would be much easier to get the right one if you can.
