need a opinion on my d16a6
Old Nov 24, 2004 | 11:02 AM
cap_og's Avatar
Default need a opinion on my d16a6
I have a 89 civic si with a custom turbo setup done by my self and my brother and i will like to know if the numbers we got from the engine are good . We tune the car at 23psi at the dyno and the results where 330 whp. is that ok for a d16a6 engine?
Old Nov 24, 2004 | 12:33 PM
platinum00's Avatar
Default Re: need a opinion on my d16a6 (cap_og)
why would that not be ok.
the motor has like 94whp stock..
what is your setup ?
platinum.
Old Nov 24, 2004 | 01:40 PM
sporkcrx's Avatar
Default Re: need a opinion on my d16a6 (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">the motor has like 94whp stock..</TD></TR></TABLE>
Mine dyno'd at 110whp stock, so sit down
Old Nov 24, 2004 | 01:43 PM
ExospeedAMcrx's Avatar
whats the engine setup and the turbo setup. Compression? Turbo size? Engine management?
Old Nov 24, 2004 | 01:53 PM
14bcoupe's Avatar
Default Re: (exospeedAMcrx)
i hope your joking,you made well over 200whp over stock with 23psi on a D non vtec and your asking if thats ok,geez.
Old Nov 24, 2004 | 01:56 PM
onePOINTsix's Avatar
Default Re: (14bcoupe)
actually it's proven that the A6 heads stock flow better then a Z6 head with a mild port job, the only thing hold it back are the valves... why do you think Exospeed's All Motor D16 is running a non-VTEC head
Old Nov 27, 2004 | 05:27 AM
cap_og's Avatar
i have ross 8.5:1 comp .020 over, eagle rods , web cam 273 cam, stock headwith skunk2 springs, retainers and cam gear, venom intake manifold and fuel rail with 720cc injectors, bosh fuel pump, custom turbo header,
40mm tail wastegate, t3/t4 turbo (can tell to much about turbo size, if you Know what i mean) 3" exhuast, msd 6a and coil, wolf3d engine management system.
brutekiller787
Dec 7, 2015 03:19 AM
whteteg8901
Apr 3, 2007 01:18 PM
Schister66
Oct 28, 2006 05:15 PM
White86CRXSi
10
Oct 9, 2004 09:50 PM
LoyaLT
Jun 15, 2003 08:59 PM
