Just changed out a clutch, not it wont start :S
Old Nov 24, 2004 | 10:45 AM
migs's Avatar
Default Just changed out a clutch, not it wont start :S
Uhmm, I just changed out a clutch and its not starting. The car turns over.
I plugged all plugs back in. It does not want to fire up. Sometimes I can BARELY get it started idling at 200rpm but it dies out. Ground wire to tranny is bolted back on. O2 sensor is plugged back in.
What could it be? It turns over but does not get spark. I also checked spark plugs/cap/rotor/etc
(puts flame suit on)
EDIT: no check engine
Old Nov 24, 2004 | 11:01 AM
AssPenny's Avatar
Default Re: Just changed out a clutch, not it wont start :S (migs)
Can u hear the fuel pump prime when you first turn the key on?
Old Nov 24, 2004 | 11:02 AM
mr2slo4u's Avatar
turn your kill switch off
Old Nov 24, 2004 | 11:03 AM
migs's Avatar
Default Re: Just changed out a clutch, not it wont start :S (AssPenny)
Yes
Old Nov 24, 2004 | 01:07 PM
Dan GSR's Avatar
is it possible you put the clutch disc on backwards?
Old Nov 24, 2004 | 01:16 PM
Slow_Em1's Avatar
Default Re: Just changed out a clutch, not it wont start :S (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">is it possible you put the clutch disc on backwards?</TD></TR></TABLE>check your starter and all the grounds i did this too a while back.
Old Nov 24, 2004 | 01:17 PM
Pootie's Avatar
Far fetched idea, but is the engine harness ground still hooked up to the thermostat? Make sure it's tight. I know you dont' have to take it off to take tranny off but I've seen it happen before. That ground goes to your ecu.
Old Nov 24, 2004 | 02:16 PM
Bbasso's Avatar
double check every wire you un-clipped, make sure the battery is also connected properly.
and if you can take a look in your intake, make sure you did not leave a rag or something in there.
migs's Avatar
WTF! Man, is it even possible to put the disc on backwards?
Old Nov 24, 2004 | 02:21 PM
mikehonda's Avatar
Default Re: Just changed out a clutch, not it wont start :S (Pootie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pootie &raquo;</TD></TR><TR><TD CLASS="quote">Far fetched idea, but is the engine harness ground still hooked up to the thermostat? Make sure it's tight. I know you dont' have to take it off to take tranny off but I've seen it happen before. That ground goes to your ecu.</TD></TR></TABLE>
Thats not a far fetched idea at all. Check your harnesses out...and yes it is possible to install the clutch backwards. Although one would have to be very determined to do so!
mikehonda: who never forgets his mistakes
Old Nov 24, 2004 | 03:04 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">
WTF! Man, is it even possible to put the disc on backwards?</TD></TR></TABLE>
I've heard of people who have done it
Old Nov 24, 2004 | 06:54 PM
92TypeR's Avatar
FSAE
Sounds like tranny ground is missing.
Old Nov 24, 2004 | 08:09 PM
migs's Avatar
Default Re: Just changed out a clutch, not it wont start :S (92TypeR)
Tranny ground is there.
Old Nov 24, 2004 | 08:25 PM
JDM CTR '00's Avatar
You got gas in the tank right ?
Old Nov 24, 2004 | 10:49 PM
GZR4DR's Avatar
Default Re: Just changed out a clutch, not it wont start :S (JDM CTR '00)
Double check and make sure you didn't put the map/TPS sensors on backwards. It should throw a code but you never know.
Old Nov 25, 2004 | 11:30 AM
Slow_Em1's Avatar
Default Re: Just changed out a clutch, not it wont start :S (GZR4DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZR4DR &raquo;</TD></TR><TR><TD CLASS="quote">Double check and make sure you didn't put the map/TPS sensors on backwards. It should throw a code but you never know.</TD></TR></TABLE>?????? you dont unplug those to take a tranny off.
check all connections on starter, and check the ground on the water pump.
Old Dec 9, 2004 | 07:05 AM
migs's Avatar
Quick update: Clutch disc was NOT installed backwards, instead the clutch disc part that hooks up to the input shaft, something was too long and had to be shaved down.
Old Dec 9, 2004 | 07:10 AM
migs's Avatar
Default Re: Just changed out a clutch, not it wont start :S (Bbasso)
Ooops, edit.
I thought all Bseries clutches (as long as they were hydrolic) were the same?
Old Dec 9, 2004 | 07:17 AM
Bbasso's Avatar
Old Dec 9, 2004 | 08:14 AM
Jowee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">Ooops, edit.
I thought all Bseries clutches (as long as they were hydrolic) were the same? </TD></TR></TABLE>
I'm pretty sure they are. That shouldn't have to do anything with it not wanting to idle though. Check your ground wires again migs. I had the same problem, but it was the ground. Try to see if you can reground it or mount it somewhere else or even add another.
Old Dec 9, 2004 | 08:22 AM
migs's Avatar
Default Re: Just changed out a clutch, not it wont start :S (ITR 98 1162)
I towed the car to VSV and stoney said the clutch was different?! They took care of it.
Old Dec 9, 2004 | 08:24 AM
Ekizzle's Avatar
Good luck migs ...
Old Dec 9, 2004 | 08:30 AM
Jowee's Avatar
That's strange. Len told me he's used an LS clutch in his ITR and I've used a GSR clutch in my LS. What kind of clutch did you use Migs?
Old Dec 9, 2004 | 09:00 AM
Willard's Avatar
you had a cable release bearing vs. hydro?
Old Dec 9, 2004 | 09:02 AM
migs's Avatar
Default Re: Just changed out a clutch, not it wont start :S (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">you had a cable release bearing vs. hydro?</TD></TR></TABLE>
Hmmmm, the release bearing was purchased from Oreilleys......this could explain it.
