Integra Door - steel or aluminum?
I have a small crack in the door that needs to be welded - anyone know if the doors on a '96 Integra LS are made from Steel or Aluminum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist »</TD></TR><TR><TD CLASS="quote">Be careful, it is suppper thing and will distort with much heat at all.</TD></TR></TABLE>
"suppper thing"........i think that's atheist for super thin.
My advice is to use a small 110v mig machine and put spots over the crack. Space them out, then go back between tacks...over and over till they're about 1/4" apart. Don't try to weld it solid or you WILL warp your door. Then grind it flush, bondo and paint.
lv6l
Aug 5, 2008 07:29 AM
ekcivic9
Dec 15, 2005 09:45 PM
