TURBO TIMER HARNESS for 1992-2000 Civic and 1994-2000 Integra
The ORIGINAL and one and ONLY Turbo timer harness now available for 1992-1995 Civics, 1996-2000 Civics (incl. Si) and 1994-2000 Integras.
STOP cutting your factory wiring to install the turbo timer. Use the NEW SVE Turbo timer harness for a plug and play installation. Makes your timer install a snap !
Link to order is here: ORDER A HARNESS HERE
Install pictures right here:
UPDATED:
Plug and play with all current A'PEXi, HKS, Blitz, and Greddy turbo timers. Please check pin configuration below. If your 3-pin connector has these properties (and looks like this), it will plug and play. If not, simply cut the 3-pin plug off of our harness and simply wire in your timer.
UPDATED:
Theoretically, you could use this to keep from cutting some of the wires when installing an alarm.
Thanks,
TOm
Thanks,
TOm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightning »</TD></TR><TR><TD CLASS="quote">Theoretically, you could use this to keep from cutting some of the wires when installing an alarm.
Thanks,
TOm </TD></TR></TABLE>
well i wasn't refering to the alarm install. i was refering to the fact that some people with turbo timers can't arm their alarms while the timer is counting down. i know they say you have to use a relay in the wiring somewhere (don't ask... i suck at wiring). i was wondering if this harness has any provisions for remedying that problem.
Thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M.A.R.C. »</TD></TR><TR><TD CLASS="quote">
well i wasn't refering to the alarm install. i was refering to the fact that some people with turbo timers can't arm their alarms while the timer is counting down. i know they say you have to use a relay in the wiring somewhere (don't ask... i suck at wiring). i was wondering if this harness has any provisions for remedying that problem. </TD></TR></TABLE>
Ah, gotcha, that is really an alarm problem since the most alarms won't arm if the car is running; it has nothing to do with the harness. The harness would indeed make it nicer to fix this issue since you can cut the harness wiring and modify it instead of the actual car wiring. We had a solution(10 years ago) for this problem but it might be different depending on the alarm you have installed. You can check the link at: http://www.lightningmotorsports.com/techmwa.htm
Tom
Tom
ah ok... that's exactly the wiring diagram i was thinking about. bump for a very convenient harness though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95hatch »</TD></TR><TR><TD CLASS="quote">bout two weeks too late
Sorry, I feel your wiring pain
</TD></TR></TABLE>Sorry, I feel your wiring pain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by threatcon13 »</TD></TR><TR><TD CLASS="quote">bump for tom! awesome seller w/ excellent service and prices.</TD></TR></TABLE>Thanks for the
, we appreciate your business !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR »</TD></TR><TR><TD CLASS="quote">when will 99-00 civic harness be out?</TD></TR></TABLE>
hella bump i want to know too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR »</TD></TR><TR><TD CLASS="quote">when will 99-00 civic harness be out?</TD></TR></TABLE> Currently available !! Thanks,
Tom
Tom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">
hella bump i want to know too.</TD></TR></TABLE> Ditto on the above reply...now available !!
We've confirmed applications all the way to 2000, 2001 still has to be checked. Thanks,
Tom
Tom
I have an HKS type 0 turbo timer(its definetly old school)....this will work with mine?The pigtail is somehow universal i take it?
you would not want to do this type of wiring for your alarm. it just makes it super easy to steal. its already easy enough as it is to steal a honda. that wire harness has all the wires in it needed to hot wire your car except for the starter wire ( still easy to find)
if you dont hide your wires and connections good enough your just making it easier for a thief to hot wire your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">I'm interested, but need to know if this will work with ALL HKS turbo timers or just the more recent ones?</TD></TR></TABLE>
I'd like to know the same thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">I have an HKS type 0 turbo timer(its definetly old school)....this will work with mine?The pigtail is somehow universal i take it?</TD></TR></TABLE> Yes, semi-universal. Check the updated information above to see if it will plug and play. If not, you can simply cut our plug off and wire into our harness directly. Thanks,
TOm
TOm
