Crazy RPM's and I need a diagram
Old Nov 24, 2004 | 06:54 AM
Streamline's Avatar
Default Crazy RPM's and I need a diagram
so my 87 accord (with an 88 engine) is laughing in my face. sometimes just idling, the rps will start to go up, then down...and it's not just the dial, the engine is actually reving and slowing down. does anyone know why it's doing this? bad starter coil? i tried searching the forum and couldn't find anything. any help would be apriciated.
secondly, i was wondering if anyone had a diagram of the vaccum lines for the accord (88 engine i guess...) i want to see if mine is hooked up properly. thanks for the help
Old Nov 24, 2004 | 07:59 AM
matt_in_sd's Avatar
Default Re: Crazy RPM's and I need a diagram (Streamline)
Most likely you have a vacuum leak or a problem in the carb.
Old Nov 24, 2004 | 08:20 AM
Streamline's Avatar
Default Re: Crazy RPM's and I need a diagram (matt_in_sd)
does anyone have a vaccum line digram?
Old Nov 24, 2004 | 08:39 AM
deadbymorning's Avatar
i had the same problem w/ my 89 lxi a few years back. the easiest thing to do is replace all the vacuum lines. you can find replacement silicone hose kits for around 20 bucks ( i used a nokya kit ) and it took about 2 hours to replace all the vacuum lines. after this the car ran noticably smoother and took care of idle/rev problem. hope this helps your dilemma
my77stang
Dec 31, 2009 08:36 PM
onimudvayne
Jul 1, 2007 07:30 PM
PhilNLucky
Jul 31, 2005 01:36 AM
outlaw42761
Jul 27, 2004 11:36 PM
honda8882
May 13, 2003 09:55 AM
