knocking sound
Hey guys i need some help
like 2 weeks ago i blow my motor and i just put a new one in well its not new its one that i had its like a brand new head (rebuild) and the block its used. It was runing fine for like 2 days until the oil light came on and it started to knock i took the oil pan off and the oil pick up was on the bottom of the oil pan it fell off lol dont know how that happened. well now i put it back on and it knocks now its like a werid knock tho its there when i give it gas and if the take out the number 2 spark plug wire out it stops knockin could this be timing or is it probly bearings or piston slap i dont know what to do someone said it could be off timing well im asking you guys please help
you spun a bearing. i am sure of the becasue when you take the load off cylinder #2 it goes away. so that is your bad bearing right there. dont dirve it and get it fixed asap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLStuner »</TD></TR><TR><TD CLASS="quote">you spun a bearing. i am sure of the becasue when you take the load off cylinder #2 it goes away. so that is your bad bearing right there. dont dirve it and get it fixed asap. </TD></TR></TABLE>
damn, that sucks...
damn, that sucks...
From: gravity rides everything...everything will fall, se GA/ne FL
could easily be a scarred up piston skirt and cylinder as well, and your bearing could be perfect. drain oil, pull pan, look for glitter specs or bearing will be obvious slivers.
Gemar
22
May 29, 2013 07:41 AM
