Will a 16x7 +30 cpr's fit on ITR's???
Old Nov 23, 2004 | 07:24 PM
NiceDc2r's Avatar
Default Will a 16x7 +30 cpr's fit on ITR's???
Will a 16x7 +30 cpr's fit on ITR's??? I have a set and i also have two spares that are +35. Will the 35 offset fit on the front and would the +30 fit on the rear? Will there be fitmint issues with the caliper and or fenders? These rims are mostly for show but i will be driving on them.
Old Nov 23, 2004 | 07:26 PM
KOALA YUMMIES's Avatar
Default Re: Will a 16x7 +30 cpr's fit on ITR's??? (NiceDc2r)
If you have them why dont you jack up the car and see the clearance and offset issues, the +30 will prob stick out a LOT, but the +35 would probably work better.
I run 15x7 +38 at stock height, if I was lowered I'd have rubbing issues.
Old Nov 23, 2004 | 07:27 PM
NiceDc2r's Avatar
Default Re: Will a 16x7 +30 cpr's fit on ITR's??? (KOALA YUMMIES)
Dont have tires yet
Old Nov 24, 2004 | 06:05 PM
jeremy.'s Avatar
up because i want to know too....or even a 32 offset?
Old Nov 26, 2004 | 12:32 AM
WAT THA!!!'s Avatar
Default Re: Will a 16x7 +30 cpr's fit on ITR's??? (ekay_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">up because i want to know too....or even a 32 offset?</TD></TR></TABLE>
up because i wanna know who's *** that is in your avator jeremy
Old Nov 26, 2004 | 12:36 AM
jeremy.'s Avatar
Default Re: Will a 16x7 +30 cpr's fit on ITR's??? (1JDMDB8)
that's me man....obviously you didn't know i worked out did you?
Old Nov 27, 2004 | 08:30 PM
OCAUTOCARE's Avatar
I have 16 by 8
I think it's like a 43 offset
I have 225/40 16's
https://honda-tech.com/zerothread?id=1057345
No problems.
Modified by seantypers at 10:02 PM 11/28/2004
Old Nov 28, 2004 | 10:57 AM
jeremy.'s Avatar
Default Re: Will a 16x7 +30 cpr's fit on ITR's??? (seantypers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seantypers &raquo;</TD></TR><TR><TD CLASS="quote">I have 16 by 8
I have 225/40 16's
https://honda-tech.com/zerothread?id=1057345</TD></TR></TABLE>
43 is pretty off from 30 offset
Old Nov 28, 2004 | 01:19 PM
OCAUTOCARE's Avatar
43 is pretty off from 30 offset</TD></TR></TABLE>
Did you want to know if 30 offset would fit?
Old Nov 28, 2004 | 03:10 PM
jeremy.'s Avatar
yes that is what he is asking for.....i'm afraid they might stick out some
Old Nov 28, 2004 | 06:09 PM
OCAUTOCARE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekay_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">yes that is what he is asking for.....i'm afraid they might stick out some</TD></TR></TABLE>
Yeah, so I have a(16 by 8, 225/40/16) 43" offset and they don't stick out. You're lip might stick out unless you get wide tires.
Modified by seantypers at 9:59 PM 11/28/2004
Old Nov 28, 2004 | 07:53 PM
NiceDc2r's Avatar
Yeah, so I have a(16 by 7.5, 225/40/16) 43" offset and they don't stick out. You're lip might stick out unless you get wide tires.</TD></TR></TABLE>
the lip???
Old Nov 28, 2004 | 08:49 PM
Man at least after all this sensless banter, go out, put it on some jack stands and see how it is on the hub, brake clearance, and how much it sticks out as is. And take pix!
Old Nov 28, 2004 | 08:56 PM
OCAUTOCARE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NiceDc2r &raquo;</TD></TR><TR><TD CLASS="quote">
the lip???</TD></TR></TABLE>
The lip of the rim.
Old Nov 29, 2004 | 08:35 AM
BUKKAKE-ADAM's Avatar
an 30 offset wheel clear the brakes but the wheels will stick out of the body. nothin an little camber cant fix / \. plus you'll have to stretch the rubber to fit.
Old Nov 29, 2004 | 04:59 PM
OCAUTOCARE's Avatar
Default Re: (eg_adam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_adam &raquo;</TD></TR><TR><TD CLASS="quote"> plus you'll have to stretch the rubber to fit.</TD></TR></TABLE>
What?
Old Nov 29, 2004 | 05:14 PM
Curt941's Avatar
Default Re: (seantypers)
I think he probably means using a skinny tire, like 195 width and then fit it to 7" wide wheel...kind of like the VW guys do...big wheels but small tires...
Old Sep 1, 2005 | 02:48 PM
ricedoutride's Avatar
Default Re: (Curt941)
whats up Josh, are you alive? maby on vacation or something? i've p.m.'d ya alot. anyone know if Josh is Alive?
Old Sep 1, 2005 | 03:02 PM
Team Bukkake Sucks!!!'s Avatar
Default Re: (ricedoutride)
<FONT SIZE="50">NICEDC2R/JOSH WAS BANNED EMAIL HIM SDJOSHSOLIS@YAHOO.COM</FONT>
FerioVtec94
Acura TSX
Jul 5, 2007 12:02 PM
jbell
Honda S2000
24
Oct 18, 2006 10:33 PM
YTYPER
Honda Fit
Apr 13, 2006 06:45 PM
JDMG3
Mar 21, 2006 01:03 PM
classciv
Mar 19, 2004 08:32 AM
