MPFI SWAP -- Distributer wiring
*MPFI SWAP ON 90 DX*
i just finished installing the SI distributer, and i dont have the distributer plug from an SI harness, but i have both DX plugs (distributer and harness side), do u have any info on how i should go about wiring this with the ca sensor?
Modified by shivern at 6:51 PM 11/23/2004
i think you can still use those plugs but you need to wire the wires from c1 & c2 direct to the dist.. there is a pic in this link that shows the wire color coating for the two dists..
the dx dizzy is the same as the zc one, so if you find a repinning diagram for si to zc, use that. and for the two wires you're missing, you must run 2 new ones to the
ecu like mr. carpenter said
scott
scott
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/zerothread?id=1063804
this info may help..
Using a DX plug, the wires are in the same basic configuration
only in a different plug..
Or this might help also:
http://www.dmoore.com/crx/zc-phase3.htm
here's that link, sorry. scroll down to the bottom.
http://www.angelfire.com/d20/h....html
well today was the day i was going to wire the distributer and CA sensor, but my auto tech teacher decided to get his bluetooth fixed. and i dont have school the next two days, then its the weekend, so monday it'll have to be.. I'll probably have more questions , thanks!
h224thgensedan
Jan 23, 2007 05:28 AM
