ITR SRS steering wheel problem
Well i searched and learned to install the ITR SRS steering wheel. i pulled the SRS fuse and installed the ITR SRS steering wheel. when i pluged everything back in, i notice the SRS light didnt go out. what could be my problem?
There is a tip on how to do it around here from some time ago involving a paperclip. Search and you will find it cause I don't have the pic.
When I did mine I just took the negative battery terminal off the battery before touching anything then put it back on only after everything was finished and no srs light for me.
if the srs light came on, you might have broken the cable reel. That is the part with two prongs that stick out of it. If it is not centered properly when you install the wheel it breaks = SRS light
thewrai6th
Jan 15, 2009 05:28 PM
