h22 crx
Old Nov 23, 2004 | 04:32 PM
CrxSiR-GNY's Avatar
Default h22 crx
whats up everybody...i am new here, but not to imports...i have an 89 crx si...i want to do something that not alot of people do and the first thing that came to mind was a h22. nobody around me has ever even attempted it so i think thats what i want. i was wondering if anybody could tell me most of the procedures and parts i will need for the swap, especially thiongs that have to be done custome or specially for the crx...thanks alot.
Travis
Old Nov 23, 2004 | 04:33 PM
Creepshow S60's Avatar
Default Re: h22 crx (Bigtmanx00x)
well first thing is you need a lot of money.
try using the search feature on the site. It will give you a wealth of info...
Old Nov 23, 2004 | 04:34 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtmanx00x &raquo;</TD></TR><TR><TD CLASS="quote">.i want to do something that not alot of people do </TD></TR></TABLE>
I guess its not searching. Do a search for h22 crx.
Old Nov 23, 2004 | 04:36 PM
TIRENECK's Avatar
Default Re: h22 crx (90blackcrx)
the cost of this swap will go a bit lower with the hasport mounts.
edit: yea shoulda mension they aint out yet.
Default Re: h22 crx (TIRENECK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TIRENECK &raquo;</TD></TR><TR><TD CLASS="quote">the cost of this swap will go a bit lower with the hasport mounts.</TD></TR></TABLE>
What hasport mounts did you want him to use ? Hasport does not make mounts yet for this engine swap.
Old Nov 25, 2004 | 09:01 AM
CrxSiR-GNY's Avatar
hey i really appreciate all of the feedback...i understand that it is a heavier motor but i am building it to run at the track...i have found a place Enjo Racing that has mounts, axles, and shift linkage for the h series into a crx...if i perchase these products will the swap go in pretty easily? or will i still have to do custom work and stuff? and also what is the best way to reinforece the suspension? thanks alot
Travis
Old Nov 26, 2004 | 08:27 AM
shaddr3's Avatar
If I were you, I would seriously buy an adapter plate from that guy on these forums, and just use a B series tranny. That way, the engine doesnt weigh as much (because of the H series tranny being replaced), and also its much easier to install everything, and you just have to buy EF mounts. So all you need is to ahve your car setup with the EF Mounts and B16 tranny, get yourself that plate and a H22a block, then your set to go.
Old Nov 26, 2004 | 09:38 AM
The DX Rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigtmanx00x &raquo;</TD></TR><TR><TD CLASS="quote">i have found a place Enjo Racing that has mounts, axles, and shift linkage for the h series into a crx...if i perchase these products will the swap go in pretty easily? </TD></TR></TABLE>
have you contacted them for pricing and if they are available? i went to the site as well and if they are legit imma do an h22 swap as well in my crx
Old Nov 26, 2004 | 10:25 AM
CrxSiR-GNY's Avatar
Default Re: h22 crx (nyhustla2k)
i appreciate all of the feedback and tips...i was considering the adapter plate for the tranny but i am trying to find out if a b-series ratios are better than the h-series....does anybody know which is better for the h22 motor? because my first thought would be to stick with the tranny that honda made for the motor...but i would appreciate anybodys imput on that...where can i buy the plate?
on the websight it says you need to call for for pricing...i havent called yet but i am planning on doing it soon...when i do call i will post up and let you know how much everything will be roughly...
keep the feedback and tips coming in i need all the help i can get...thanks...
Travis
Old Nov 26, 2004 | 01:49 PM
brent_G's Avatar
they wouldnt make the adaptor plate if the ratios where better on the h22 tranny.
The b series h22 combo would rule. If i was to h22 my rex it would definatly have to be with a b16 tranny.
Old Nov 26, 2004 | 05:49 PM
2point2's Avatar
Default Re: h22 crx (y-49CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX &raquo;</TD></TR><TR><TD CLASS="quote">well first thing is you need a lot of money. </TD></TR></TABLE>
nah...
you need to know (or learn, like i did) how to fabricate.. and have to have some patience.
i'd like to see more people try out that adapter plate though.. i wish that was around when i started.
Old Nov 26, 2004 | 06:31 PM
301am's Avatar
i talked to a guy here who i guess you can call the h22 guru in the city, hes got his own business and such...his other car is a h22 crx, and basically he told me its not worth it and to do a B swap...he said to swap into an EG would take him about 3-4 days for a good clean swap hiding wires and everything...and it took him over a month to do his crx....i was all about trying the h22 crx until i talked to him, now i think im gonna go b18c or a turbo ls
Old Nov 26, 2004 | 06:44 PM
brent_G's Avatar
Default Re: (301am)
no do h22 turbo.
Old Nov 26, 2004 | 07:16 PM
2point2's Avatar
Default Re: (301am)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 301am &raquo;</TD></TR><TR><TD CLASS="quote">..and it took him over a month to do his crx....</TD></TR></TABLE>
did you think this swap took a weekend?
..i tell people all the time not to do this swap if they show any hint that they have no clue or have no tools.
Old Nov 26, 2004 | 09:15 PM
desertrider17's Avatar
he man my buddy has a h22-a for sale with everything you need for a crx he was going to put it in his but has changed his mind.
Old Nov 26, 2004 | 11:17 PM
TIRENECK's Avatar
Default Re: h22 crx (desertrider17)
what made them change their minds? is it the breaking axles thing or the custom frabrication needed.
Old Nov 27, 2004 | 08:22 AM
CrxSiR-GNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by desertrider17 &raquo;</TD></TR><TR><TD CLASS="quote">he man my buddy has a h22-a for sale with everything you need for a crx he was going to put it in his but has changed his mind. </TD></TR></TABLE>
hey thanks for the info...do you know how much he wants for it? and what made him change his mind? and also where is he located? thanks alot
i am planning on going to romar industries and having them do the sawp for me...im not sure if anybody has heard of them...but i heard that they are amazing with motor work...i know that it is a hell of a swap and a lot of work, and i understand what it is going to take to do the wap i just dont have the experience or the tools to perform the swap myself...i have done my friends swaps for them (b16 into a ef hatch, ls into a crx, and gsr into a 94 coupe) but nothing this extreme...if anybody knows what a good price for the complete swap including wireing would be could you please let me know...thanks
Travis
Modified by Bigtmanx00x at 12:33 PM 11/27/2004
Old Nov 27, 2004 | 11:04 AM
301am's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">
..i tell people all the time not to do this swap if they show any hint that they have no clue or have no tools. </TD></TR></TABLE>
Im just saying is it worth the hassles of a months worth of work, just for 20hp, or have it done in a weekend? I guess if you have the time its alright.
Old Nov 27, 2004 | 04:01 PM
CharleyCRX's Avatar
Default Re: (301am)
i have a CRX H22A turbo
and they took me 1 year to be ready to road...
it's a lot of trouble...
and now all the newbie want the damn setup...
my h22A turbo with everything is for sale...
i will try a J engine
Old Nov 27, 2004 | 04:13 PM
TIRENECK's Avatar
Default Re: (CharleyCRX)
would you sell the turbo kit or wanna sell the whole set up?
Old Nov 27, 2004 | 04:18 PM
1point7db2's Avatar
Do you have any pics of this setup? How much boost could I run safely everyday on my H22A1 crx?
Old Nov 28, 2004 | 09:17 AM
CRexin's Avatar
hey i have a 89 CRX si with a zc in it, i bored out it 80 over which took care of my torque problem but now im here trying to figure out how ima get the horsepower with out going turbo just yet, any suggestions
...i really dont wanna swap it out unless its goin to be a h22..im stubborn
Old Nov 28, 2004 | 10:54 AM
91sihatch's Avatar
Default Re: h22 crx (CRexin)
Just go B-series unless you have the time and effort to put into a H22 swap. This kind of swap isn't going to happen in one weekend.
Old Nov 28, 2004 | 11:27 AM
.Ash's Avatar
i saw a very clean way to mount an h22 in a DA the other day by a member on here. its different than 2point2's way and the HtoB plate route but looks sweet. he cut out the integra chassis mounts and welded in factory prelude ones. in doing this, he was also able to use stock motor mounts. very cool in my opinion.
Old Nov 28, 2004 | 12:50 PM
2point2's Avatar
Default Re: (usdmPC3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmPC3 &raquo;</TD></TR><TR><TD CLASS="quote">he cut out the integra chassis mounts and welded in factory prelude ones. in doing this, he was also able to use stock motor mounts. very cool in my opinion. </TD></TR></TABLE>
I would still need a custom tranny mount but I should have tried drilling out the lude chassis mount and welding it to my chassis.
