i don't understand it why does it misfire??
Old Nov 23, 2004 | 02:52 PM
mrnice1058's Avatar
Default i don't understand it why does it misfire??
ok i finally got my b16 to start and to run, here is my problem. when i start it i need to hold the gas petal down until it gets a hold of the timing. and when i let it go it warms up i checked the timing on the dizzy and it is going with the marker on the pulley so it is in timing, now i just got a new plugs wires cap and rotor and still i have the problem. anywhere i can look to see where i am having a problem? how do i know if the dizzy is bad? to explain the problem a little better when i step on the gas it seems like it wants to turn off then it goes but when i let go of the gas it back fires one or two times can someone or anyone help me please?
Old Nov 23, 2004 | 03:03 PM
lohatch's Avatar
Default Re: i don't understand it why does it misfire?? (mrnice1058)
check this out to make sure you have the correct firing order. also check your cam timing. take a socket and turn the crank pulley to TDC. make sure both cam gears are at TDC as well. your timing belt might be off a tooth or two causing this.http://img18.exs.cx/img18/7701/b16firingorder2.jpg
Old Nov 23, 2004 | 03:42 PM
mrnice1058's Avatar
Default Re: i don't understand it why does it misfire?? (lohatch)
both arrows are at the up and the crank is on the ttc mark on the pulley the dizzy is in the right order what else could i look for?
Old Nov 23, 2004 | 03:51 PM
lohatch's Avatar
is it throwing any cels?? what ECU are you running?? i wonder if it is anything TPS related??
Old Nov 23, 2004 | 03:52 PM
mrnice1058's Avatar
no codes that is the funny part i am running a chipped p28 and the tps was replaced also i have no what else to look at
Old Nov 23, 2004 | 03:57 PM
lohatch's Avatar
the only thing i can think of is you are checking the timing wrong. are you sure when it is flashing it is the three little marks ( ||| ) on the pulley???? you voltage test the TPS??
Old Nov 23, 2004 | 07:39 PM
mrnice1058's Avatar
nope i am checking the three bars on the pulley the tps is set right i had a vafc hooked up to it and the reading was perfect so it opens and closes and the volts go up and down just right. well i was thinking i have a small leak coming from the fuel pressure reg could that be the problem also i am going to fix it tomorrow but i can't see that being the problem but what else could it be? also how do i know if the dizzy is bad? it is sending all the power to the plugs but some still think that it is the dizzy
Old Nov 23, 2004 | 07:47 PM
lohatch's Avatar
hmmm. it is kinda hard to diagnose it over the internet without listening and seeing what it does. have you taken the cap off the dist. and see what it looks like inside(make sure it's clean, etc)?
Old Nov 23, 2004 | 07:52 PM
mrnice1058's Avatar
yeah it is clean no dirty no build up nothing new cap new rotor new plugs new cables but i don't think it is my dizzy i have come to the conclusion that there is some kind of vacuum hose somewhere and because of my fuel pressure reg leaking i am sure it has something to do with it. does the pressure from the FPR have anything to do with the pressure of when i step on the gas there is no real back up?
Old Dec 1, 2004 | 08:01 AM
b16hybridsol's Avatar
its called bad karma, for being scandalous and not paying owed money. hint hint
Old Dec 1, 2004 | 08:35 AM
00Red_SiR's Avatar
All Motor Mentor
Make sure you dont have your map sensor plug, plugged into your TPS and vice versa. It happned to me once and I had similar problems, switched them around and it worked perfectly.
wagonvanny
Apr 14, 2015 06:12 PM
KenJoTuning
10
May 30, 2012 01:15 PM
jdmboy94
Apr 10, 2009 12:40 PM
teamredline9k
May 29, 2006 06:12 PM
BB6racer
Jun 16, 2005 12:04 PM
