!!! HUGE garage sale !!! Most OEM Honda/Acura !!! CHEAP !!!
if you view this, please assist me in keeping it on the first page. give her a bump.
well i am a pack rat, but i am running out of space to keep stuff. so i need to clear out the garage. this is stuff from doing swaps and buying cars for parts over the last 4-5 years. everything is in good working order, or i would not have kept it.
4-obd1 d series alternators $20ea
1-obd2 d series alt $20
3-obd2 d series ps pumps 20ea
2-obd1 d series ps pump 20ea
1-94-95 teg ps pump 20ea
2-h22 crank pulleys $12ea
3-b16 crank pulleys 12ea
2-ls crank pulleys 12ea
1-gsr crank pulley 12
2-sets gsr rods and pistons $45set
2-sets b16 rods and pistons $35set
3-internal coil obd1 h series distributors $40ea
4-obd1 d15 distributors $40ea
1-obd2 d series dist $40
2-h22 ps pumps 15ea
5-d and b series starters $25ea
3-h series starters $20ea
3-full sets of b series oem mounts (92-92 civic/94+ teg) all rubber mounts and metal brackets $60ea
6 full sets d series oem mounts $45ea
3-p72 ac compressor mounts $10ea
4-d series ac comp mounts $10ea
3-oem billet b series fuel rails $20ea
1-oem billet d series fuel rail $15
2-gsr full timing belt cover set $25ea
3-full ls timing belt cover sets $20ea
2-d16z6 timing cover sets $20ea
1-obd1 ls valve cover $25
1-b series vtec valve cover (cut over cam gears) $25
11-sets obd1 d or b series injectors (240cc) $15set
6-sets obd2 d or b series injectors (240cc) $15set
3-sets obd0 injectors (240cc) $10set
2-no name front strut bars (one blue and one silver) $10ea
2-obd1 b16 intake manifolds $25ea
3-ls intake manifolds $25ea
2-gsr intake manifolds $20ea
11-various throttle bodys all with good tps $25ea
3-cruise control units $15ea
5-sets oem b series cam gears $10set
3-b16 oil pumps $25ea
2-gsr oil pumps $25ea
4-ls oil pumps $15ea
2-h22 oil pumps $20ea
3-94-95 gsr harnesses $75ea
2-92-95 civic harnesses $75ea
2-obd2 teg harnesses$75ea
1-set 88-91 crx rear speaker brackets $15
3-92+ civic ac compressors $20ea
5-b series ac compressors$20ea
3-d series thermostat housings with water pipe $15ea
2-b series t-stat housings with water pipe with oil cooler ports $25ea
3-b series without $20ea
3-b series oil coolers $35ea
3 b series ps res. $10ea
1-5 spd swap (all pedals, master and slave cylinders, hard line and rubber line) $50
6-sets b16 ps brackets $10ea
1-set gsr/ls ps brackets $10
1-p2e ecu (99 model) $25
1-resurfaced k20a3 oem flywheel $20
1-2001 gsr rack and pinion $50
2-gsr throttle cables $8ea
1-ls throttle cable $8
4-92-95 civic throttle cables $8ea
10-tb mount map sensors $15ea
4-firewall mount map sensors $10ea
3-tps sensors $20ea
6-manifold mount iat sensors $8ea
misc wiring pigtails (injectors, vtec, ks, dist......)
lots of stock coils and ignitors
loads of other stuff, just ask if you need anything not listed.
everything is obo. just name your price, need to get this stuff outa here
Modified by ViperRedCRX at 6:30 AM 11/24/2004
2-h22 ps pumps 15ea
3-tps sensors $20ea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 »</TD></TR><TR><TD CLASS="quote">do u happen to have the cluster harnes for a dc gsr, dc ls or ek ex?</TD></TR></TABLE>
as a matter of fact i do. $25 shipped
for alot of stuff. any chance you have b series alternator? may need starter and mounts also. let me make sure money is where it should be first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limpy »</TD></TR><TR><TD CLASS="quote">damn pac rats whording all the good parts. lol
just out of curioucity would you happen to have a gsr/itr oil pan, pickup, and windage tray???</TD></TR></TABLE>
all of the above. $55 shipped for all 3
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrankencrxBHAM »</TD></TR><TR><TD CLASS="quote">ill take a gsr intake manifold.</TD></TR></TABLE>
pm me and i will get that to you
