D16y7
Old Nov 23, 2004 | 01:43 PM
jinteg730's Avatar
Default D16y7
what kinda power does this motor make
Old Nov 23, 2004 | 02:01 PM
NR_hatch's Avatar
Default Re: D16y7 (jinteg730)
not **** homie...i gots one and i dont give a ****...SWAP!!!!!!!!
Old Nov 23, 2004 | 03:34 PM
lohatch's Avatar
Default Re: D16y7 (NR_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NR_hatch &raquo;</TD></TR><TR><TD CLASS="quote">not **** homie...i gots one and i dont give a ****...SWAP!!!!!!!!</TD></TR></TABLE>
lol. if you want to extract NA power from this motor you are probably going to want to run some higher compression pistons and a vtec head.
Old Nov 23, 2004 | 03:40 PM
lohatch's Avatar
Default Re: D16y7 (lohatch)
for example a Y7 with a Y8 head and HG with d16a6(PM6) pistons yeild 10.85:1 compression. a y7 block with Z6 head and PG6B pistons would give you 11.67:1 but the PG6Bs have very small valve reliefs, which limits cam timing with an aggressive cam. the first setup would run pretty good on 91 octane and the second would run good on 93 octane. check out the compression calculator to play around some morehttp://www.knology.net/~jediklc/D.htm
Old Nov 23, 2004 | 04:29 PM
Aquafina's Avatar
107bhp
xci_ed6
Nov 16, 2004 06:40 PM
hondaless
Apr 10, 2003 09:27 AM
grncivic91
Jun 18, 2002 12:50 PM
