99 accord wont idle.
Old Nov 23, 2004 | 12:59 PM
matt_in_sd's Avatar
Default 99 accord wont idle.
On the wayto work this morning the car stalled at a light. After a bit of cursing the car restarts but wont idle. the engine light is not flashing, the car seems to have the same amount of power just wont idle. I replaced the PCV valve about 20k miles ago. 99 accord vtec 2.3l 190k miles. I figure idle control solenoid, but thought I would ask here. I dont have a scanner yet. Anybody seen this problem yet?
Old Nov 23, 2004 | 01:18 PM
Turbowa's Avatar
Default Re: 99 accord wont idle. (matt_in_sd)
Does it only die once the car is warmed up or will it die with the car cold too? This can make a difference as to your trouble shooting. Also does it run rough then die or just fall flat on its face once at idle speed?
Old Nov 23, 2004 | 01:49 PM
matt_in_sd's Avatar
Default Re: 99 accord wont idle. (Turbowa)
When I went out at lunch it died the first stop I came to. If I give it just a little bit of gas I can make it idle and it sounds/runs normal. If I am coming to a stop throw the clutch in the rpm drops normally and for a fraction of a second it tries to idle normally but the rpm's keep dropping to maybe 200 rpm, it will lope along for a second and then dies.
Old Nov 23, 2004 | 02:14 PM
Turbowa's Avatar
Sounds like you IAC valve going bad. You will need to replace it, its located ont he back of the intake mani. it has a couple of hoses going to it and a plug with 3 wires.
Old Nov 23, 2004 | 06:00 PM
matix's Avatar
turn the idle screw counter clockwise. Its located on the throttle body and uses a flat head screw driver to adjust. Go here for more help http://www.ef-honda.com/ben/Badidle.html
Old Nov 29, 2004 | 07:59 AM
matt_in_sd's Avatar
Default Re: 99 accord wont idle. (matix)
Took off the IAC valve and cleaned it up all nice an purty put it back together and it still has the same problem. So I spent $170 for a new one still no go. Now I'm getting scared it is the PCM ($571). From what the Haynes manual says the PCM has the codes for the immobilizer system, which means the dealer has to reprogram it? I verified 12volts and gnd are getting to the connector, but I dont know what the control signal should be. There are no DC volts on the control line. Does anybody know what the control signal is?
Old Nov 29, 2004 | 08:09 AM
f23accord's Avatar
Same thing happened to my friend's integra...turned out his fuel injectors were bad, might want to check them out.....his car would start too but wouldnt idle, so after he started it up he had to keep gasing it to keep the car from dying on him
Old Nov 29, 2004 | 09:15 AM
matix's Avatar
Default Re: 99 accord wont idle. (f23accord)
Hey did you try turning the idle screw counterclockwise on the throttle body. I know if thats too tight its will bog the car not letting it idle.I highly doubt its your pcm so save your money. Its probably that idle screw it has a plastic cover over it. Its a flat head check it out. Let me know if that doesnt work.
Old Nov 29, 2004 | 10:23 AM
matt_in_sd's Avatar
I will try it tonight.
Old Nov 29, 2004 | 12:26 PM
matix's Avatar
Ok let me know if you have any problem with it. Its right at the top left of the tb.
Old Nov 30, 2004 | 07:48 AM
matt_in_sd's Avatar
That worked. Does this mean the TB is getting plugged up? Do I need to take it off and give it a gumout bath? A whole lot cheaper then $571 for the PCM. Thanks for the help.
Old Feb 6, 2005 | 11:58 PM
eauto's Avatar
Modified by eauto at 5:02 AM 2/7/2005
jkrueger2020
Jun 18, 2012 05:01 PM
accord 2 door
Aug 15, 2011 05:55 PM
kitt
Apr 29, 2010 11:57 AM
unhappy_idle
Feb 13, 2006 06:50 AM
yellowdcn
Feb 28, 2005 12:05 PM
