zc swap details
Old Nov 23, 2004 | 10:17 AM
SkankyEJ7's Avatar
Default zc swap details
I need to know where i can find a quality ZC motor to swap
ANd what all i would need for a 4th gen EF civic to make it work
The car it is going into is a autyomatic
and what i would need to do as far as transmissons are concerned
I searched and couldnt find what i needed
Old Nov 23, 2004 | 10:26 AM
hatchinprogress's Avatar
Default Re: zc swap details (hondakid1)
well you need do have fuel injection (so if the car has a carb. you need to make it mpfi.) you can use the zc tranny but you would have to use intermediate shaft(im not sure about an automatic) but i would say use si 5spd. zc or integra ecu and thats all i can remember for the most part the zc is just a "drop in" as far as searching: use dohc(for the zc) because zc is too short to search for
Old Nov 25, 2004 | 06:42 PM
SwissChEz82's Avatar
Default Re: zc swap details (hatchinprogress)
I've seen plenty of ZC swaps done, however I've never seen an automatic ZC swap done. I'm sure someone here has at least seen one.
Old Nov 25, 2004 | 06:50 PM
Shiro Z31-T's Avatar
Default Re: zc swap details (SwissChEz82)
Are you keeping it auto or changing to 5 speed... If you swap to 5 speed you need all new pedal setup, clutch cable, etc.
My ZC motor had an auto "flywheel" when I bought it, so i had to get new clutch and flywheel to replace that. My car was originally 5spd though....
Old Nov 25, 2004 | 07:24 PM
31flavorscivic's Avatar
Default Re: zc swap details (Shiro Z31-T)
making the swap an automatic is going to be a very large NIGHTMARE. For a fact the mounts wont match up, because the transmission is huge, and its going to be slow with the slushbox anyways. Convert!
Old Nov 25, 2004 | 08:52 PM
wompwomp61's Avatar
ebay has a bunch of shops that sell zc's. remember there's two. a sohc one and a dohc one. make sure you find out all the info on each.
Old Nov 28, 2004 | 10:23 AM
SkankyEJ7's Avatar
Default Re: zc swap details (wompwomp61)
Yeah were doin this to one of my friends 86 hatch were gonna put a Dohc ZC in it with a manual, sorry bout that typo. I was wondering about goin from the carbed EW1 to ZC mpfi and the wiring
thanx for the help
My Swap is commin later on for EK .
ekay08
Feb 14, 2008 10:04 AM
contender
Jul 2, 2005 08:14 AM
justinau
Mar 26, 2004 06:52 AM
1point5CRX
Oct 16, 2003 10:23 AM
MR CRX
Aug 15, 2002 08:36 PM
