AEBS Intake mainfold and hondata gasket
Old Nov 23, 2004 | 08:50 AM
grenthang's Avatar
Default AEBS Intake mainfold and hondata gasket
I cant get my aebs intake mainfold and my hondata intake mainfold gasket to seal right. Is there an other method of sealing them.
Old Nov 23, 2004 | 09:39 AM
cjohnson_2's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (grenthang)
I just torqued mine properly and Ive never had a problem. could try using some hondabond around them I guess..
Old Nov 23, 2004 | 05:39 PM
grenthang's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (cjohnson_2)
All the bolts are tight the gasket just doesnt seal i am guessing.
Old Nov 23, 2004 | 06:15 PM
b19coupe's Avatar
I am using the AEBS intake manifold and Hondata intake gasket on my ITR. I got longer intake manifold studs, and sandwiched the Hondata gasket between two OEM intake gaskets. No leaks.
Old Nov 23, 2004 | 09:00 PM
91sihatchback
Guest
Posts: n/a
bump
Old Nov 24, 2004 | 01:27 AM
Matty.'s Avatar
Default Re: AEBS Intake mainfold and hondata gasket (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">I am using the AEBS intake manifold and Hondata intake gasket on my ITR. I got longer intake manifold studs, and sandwiched the Hondata gasket between two OEM intake gaskets. No leaks. </TD></TR></TABLE>
Are the longer studs really necessary?
BTW, where did you get them? Are they an OEM part?
Old Nov 24, 2004 | 05:53 AM
b19coupe's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (gumtape_deathmatch)
The OEM ITR studs were a little short for my taste, not many threads left for the nuts to grab. RSX-S studs is what I used.
Old Nov 24, 2004 | 06:15 AM
grenthang's Avatar
i think i might just try the two gasket thing
Old Nov 24, 2004 | 07:03 AM
Matty.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grenthang &raquo;</TD></TR><TR><TD CLASS="quote">i think i might just try the two gasket thing</TD></TR></TABLE>
I dont get it......you pay 5x what a quality OEM piece goes for and it still doesn't get a good seal..?!
If I pay $60 for the hondata one and still need to buy 2 OEM ones to make it work....count me out.
Old Nov 24, 2004 | 07:34 AM
FairlightRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumtape_deathmatch &raquo;</TD></TR><TR><TD CLASS="quote">
If I pay $60 for the hondata one and still need to buy 2 OEM ones to make it work....count me out.</TD></TR></TABLE>
Exactly! For nuts, bolts, gaskets, etc I would rather have OEM over aftermarket any day. Its always the best stuff.
Old Nov 24, 2004 | 12:01 PM
Terrible One's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (FairlightRacing)
the IM gaskets at An-R.com are cheaper than hondata and does the same job
http://an-r.com/intakegasket.htm
$35 shipped
Old Nov 24, 2004 | 10:03 PM
matman4444's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (orig1nalkhmersta)
some people have had fitment probs with the an-r
Old Nov 24, 2004 | 11:22 PM
grenthang's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (matman4444)
yeah i am really tired of messing with it so i have just decided to run the factory i am sure its not going to make much of a difference to run the factory one anyways
Old Nov 25, 2004 | 08:23 AM
cjohnson_2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grenthang &raquo;</TD></TR><TR><TD CLASS="quote">yeah i am really tired of messing with it so i have just decided to run the factory i am sure its not going to make much of a difference to run the factory one anyways</TD></TR></TABLE>
your absolutely wrong
Old Nov 25, 2004 | 09:09 AM
grenthang's Avatar
i would love to keep using it but everthing i do doesnt work.
Old Nov 25, 2004 | 09:26 AM
B-B-K's Avatar
I have an AN-R, no fitment issues and no leaking.
Did you tighten the bolts down in sequence? Working from the inside out? I snugged mine up in sequence first then went and tightend them down with my torque wrench arm.
Hope this helps.
Old Nov 25, 2004 | 09:56 AM
grenthang's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (B-B-K)
yeah i did that twice
Old Nov 26, 2004 | 08:53 AM
matman4444's Avatar
If you have a stock gasket you could try using the hondata and the stock one together, or buy one more and do the hondata gasket sandwich like the other dude.
Old Nov 26, 2004 | 02:17 PM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grenthang &raquo;</TD></TR><TR><TD CLASS="quote">I think I might just try that two gasket thing.</TD></TR></TABLE>
Thats why you dont have a seal, you are supposed to have an OEM gasket on each side!
Old Nov 27, 2004 | 06:01 AM
PupaScoopa's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (hybrid_vtec)
I don't have an OEM gasket on either side and it seals up just fine with my AEBS IM.
Can you tell where that gasket is leaking? Is it sitting flush all around? Have you checked the IM mounting surface for flush by just seating the gasket against it?
I bought the Hondata over the AN-R because AN-R didn't return two of my phone calls to place an order. I guess they didn't want my business. Hondata was friendly and happy to take the order.
Old Nov 27, 2004 | 07:34 AM
Used2beAb16's Avatar
Default Re: AEBS Intake mainfold and hondata gasket (PupaScoopa)
mine sealed just fine w/o two gaskets. btw i am also running the Hondata, im going to reuse it again whenever i install my AEBS manifold, and im willing to bet it will seal just fine again.
Old Nov 27, 2004 | 04:24 PM
grenthang's Avatar
Yeah the gasket is seating flush on the head and this is the 2nd motor i have put the gasket on.
Old Nov 28, 2004 | 09:51 PM
PupaScoopa's Avatar
So where exactly is it leaking? Do you have a caliper to check the thickness of the gasket and ensure that it's uniform? There could have been a screwup at the factory and one small part of it is thinner than the rest.
Old Nov 28, 2004 | 09:54 PM
ANR008's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matman4444 &raquo;</TD></TR><TR><TD CLASS="quote">some people have had fitment probs with the an-r</TD></TR></TABLE>
we had one bad production run and a few gaskets made it to market with misaligned holes. this problem was caught right away and resolved.
Old Nov 29, 2004 | 06:09 PM
grenthang's Avatar
its leaking around the top of the gasket
