d16y7 Cable Tranny HELP ASAP!!
Old Nov 23, 2004 | 06:21 AM
TheNasty0ne's Avatar
Default d16y7 Cable Tranny HELP ASAP!!
My clutch is engaging really really low...
Tranny and everything is stock..
After doing a search...
I found out it could be fluid.. or that it needs an adjustment..
My question is how do I adjust it
and how do I check tranny fluid levels
BauleyCivic's Avatar
Risky Business
Default Re: d16y7 Cable Tranny HELP ASAP!! (IncrediVtec)
D16Y7's don't have cable trannies.
But to answer your question, you're running low on brake fluid and probably have a leak somewhere. Check the clutch slave cylinder and clutch master cylinders first for leaks.
Old Nov 23, 2004 | 06:27 AM
Default Re: d16y7 Cable Tranny HELP ASAP!! (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">D16Y7's don't have cable trannies.
But to answer your question, you're running low on brake fluid and probably have a leak somewhere. Check the clutch slave cylinder and clutch master cylinders first for leaks.</TD></TR></TABLE>
Wow...haha im such a noob
brake fluid?
Thanks
Old Nov 23, 2004 | 06:44 AM
Risky Business
The clutch works just like the brakes. It uses lines and a fluid that doesn't compress to move the clutch. You press on the clutch pedal, and you push the fluid through the lines and against the clutch fork, and that engages and releases the clutch.
dazebreak
Oct 22, 2013 11:42 AM
m3 boostin
May 30, 2007 01:20 PM
Pensar71
Jul 23, 2006 05:25 PM
cyrock
May 26, 2005 07:36 AM
TedR719
18
Apr 27, 2004 07:29 PM
