gsr IM on b16 head (this is for real, I searched) ( ITB's)
Old Nov 23, 2004 | 06:13 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default gsr IM on b16 head (this is for real, I searched) ( ITB's)
So I fucked up and accidentally bought myself a set of GSR diy itb's...and they're destined for a b16 head. Now before you say search, I did, and all I found was people saying the it couldn't be done. But what's stopping a gsr mani from fitting on a b16 head? just bolt pattern? do the coolant passages line up? all that's messing me up is the flange, its itbs, not a whole manifold...help me out.
Old Nov 23, 2004 | 10:20 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: gsr IM on b16 head (Slimm-rw-)
bump for info
Old Dec 7, 2004 | 04:42 AM
SOHFAST94's Avatar
I guess since the H-t flamers won't answer I may be of some assistance. As for the difference between the two manifolds is the water lines for the most part. I can't recall if the bolt pattern is different although I don't believe that it is. Go to earls fittings and get a barbed 3/8' fitting and then drill and tap to the second hole on the b16 head and it should work. Basically all you're trying to aciheve is the water passage. I can't remeber if the flange is upside down on the GSR. I'm not a oh holy GSR fan so I don't know. Got any pictures of these things?
Old Dec 7, 2004 | 04:45 AM
Slimm-rw-'s Avatar
I'm a Jackass
Default Re: gsr IM on b16 head (SOHFAST94)
I have some, btu I dont' thikn any are of the water passages. I'll have to take soem more later.
Old Dec 7, 2004 | 10:10 AM
Phatch99's Avatar
bolt patterns are different.
Old Dec 7, 2004 | 08:31 PM
PrettyLude's Avatar
yeah bolt patterns are different
jayponz
Dec 14, 2013 03:26 PM
Black R
Dec 29, 2012 03:19 AM
EFjoe91
Aug 29, 2010 08:22 AM
slikwilly
Jun 13, 2008 05:34 PM
vwhonda2gether
Jan 11, 2004 11:55 PM
