Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Info required on changing to 205/50/15 tires
Old Nov 23, 2004 | 04:20 AM
Ki11erB's Avatar
Default Info required on changing to 205/50/15 tires
Hi guys. I drive a civic EK and do a fair bit of autocross. I'm currently using all 195/55/15 tires. I've searched on topics regarding using 205/50/15 tires infront and 195/55/15 in the rear, and most ppl seem supportive of this. So I plan to do it.
My question : Would the wider 205 tires touch the fenders or the fender underlining when doing hard cornering? Any adjustments required in order to fit these tires in an EK? My rims are enkei cps2 : 15"x7jj, offset 43, 4 hole, PCD100.
Thanks in advance
Old Nov 23, 2004 | 06:06 AM
AutoXer's Avatar
Default Re: Info required on changing to 205/50/15 tires (Ki11erB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ki11erB &raquo;</TD></TR><TR><TD CLASS="quote">
What suspension are you running? I'm running lowered onto Eibach Pro-Kits, and was fine running my 205 street tires at an event. The only time I've rubbed is occasionally when I'm turning full lock out of my lot, which is angled.
Old Nov 23, 2004 | 02:16 PM
Weston's Avatar
Depends on the offset of the wheel and what your camber is... On my '97 Integra with 40 offset wheels and 205/50-15 Azenis I don't have any rubbing problems. I'm lowered 1.75" in the front, but I did not "correct" the camber for obvious reasons. Getting rid of the negative camber will increase your chances of rubbing.
88ED8
Feb 11, 2006 11:16 AM
2000_CivicDX
Nov 8, 2005 09:18 PM
EK k kay
Jan 20, 2005 03:05 PM
p0pe
Aug 16, 2003 01:34 AM
Lookincrazy
Apr 13, 2002 07:13 PM
