b18c1 motor question please help
Old Nov 23, 2004 | 12:35 AM
drastikchangez's Avatar
Default b18c1 motor question please help
is the motor on a 94 gsr the same as a 96 gsr motor and whats the difference between a 94 and 96 gsr. any help would be greatly appreciated.
Old Nov 23, 2004 | 08:20 AM
IN VTEC's Avatar
Default Re: b18c1 motor question please help (drastikchangez)
The changes made mostly pertained to the emissions equipment and wiring harness-related items.
Changes to the harness sockets: fuel injectors, alternator, distributor
Additions (appending to existing OBD-1 systems): CKF sensor
Other changes:
EVAP system was altered and the purge solenoid is now mounted in the middle of hte manifold instead of off to the side.
Oil cooler deleted, facilitating a change in the main water pipe and block that deleted a couple of coolant nipples
FITV deleted, facilitating a change in the thermostat housing that deleted a nipple
IACV changed, uses a different bolt pattern (I think b/c I can't remember this too clearly)
I think that's it, but I probably missed something or other.
Old Nov 23, 2004 | 12:56 PM
thank u sir
reaper562
10
Jul 4, 2011 10:15 PM
Otis37
Apr 2, 2009 06:48 PM
undagroundrican
Mar 11, 2008 04:27 PM
zipperchamp
Dec 25, 2007 07:12 AM
